Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-22-2017, 11:57 PM   #1
graymond1967
graymond1967's Avatar
Oil pressure gauge wiring
I am converting my 67 mech oil pressure gauge to an electric gauge. The gauge I have is from a 1980 square body. It has three studs on the back. One is ground, one is power and one is the feed from the sender.
Does anyone know which is which, or is it going to be trial and error? I am also using the volt gauge which seems to be wired the same as an auto meter gauge. Is the oil pressure similar?
Thank you
Ray
1967 Chev C10, in the family since 1967, iron head 502, turbo 350, white with red, unrestored.
1970 Acadian SS350, 350 with muncie 4 speed, 12 bolt, best time 13.414 @ 103.72
graymond1967 is offline   Reply With Quote
Old 05-23-2017, 09:30 AM   #2
blazer2007
Re: Oil pressure gauge wiring
left -sender .right -12 volt. bottom ground. I just followed the circuit board and that,s what I came up with. This is looking at the gauge from the back side where the pins are.
blazer2007 is offline   Reply With Quote
Old 05-23-2017, 11:56 AM   #3
graymond1967
Thank you.
One last question, do i need to isolate the pins from the metal backing? My volt gauge has a small piece between two pins that isolates it from the mount.
thanks again.
Ray
Old 05-24-2017, 09:14 AM   #4
blazer2007
Not sure what you mean but I would isolate the pins from touching anything
Old 05-24-2017, 11:01 AM   #5
graymond1967
And that is what I meant. Thank you.
Ray
