Old 05-23-2017, 08:41 PM   #1
Sturvin
4L60e PNP/NSS wiring questions
First off, swapping an 01 LM7 and 4L60e into a 69 c10.
When I go to wire the PNP / Neutral Safety Switch, the smaller 4 pin (c1) connector all goes back to the ECM, simple enough.
The larger 7 pin (c2) connector is where I am in doubt.
All but the ground wire (pin D) go back to the under hood fuse block, which I don't have the other half of and will be making my own to replace.
I dug around on LT1Swap for a while and came across some wiring diagrams.
Does this look correct?
A - Not Used
B - Ignore
C - 12v Key ON
D - Ground
E - 12v Key START
F - To 15A fuse, then Rev Lights
G - To relay for starter
Full sized here -> https://goo.gl/photos/miS5fubVpkZ47jef8
Sturvin is offline   Reply With Quote
