06-01-2017, 11:27 PM | #1 |
Senior Moment
AC on 5.7 in 70 C10- Kwik? Holley? Sanden? HIGH mount
Like the title says I'm looking for info on any high mount AC brackets. It's been determined that I can NOT use the low mount. I've looked at all the above just would like to hear from someone who used the product. I like the Kwik but hear it likes to jump belts. Anybody??
Thanks Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
06-03-2017, 12:26 AM | #2 |
Senior Moment
Re: AC on 5.7 in 70 C10- Kwik? Holley? Sanden? HIGH mount
Nobody??????
06-04-2017, 10:50 PM | #3 |
I would look into the dirty dingo high mount. It looks to be a quality piece with a heavy duty tensioner.
06-05-2017, 09:24 AM | #4 |
They work !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
06-06-2017, 11:51 AM | #5 |
ICT Billet has various options for AC mounts and I have found them much more affordable than some other mfr's
http://www.ictbillet.com/ls/brackets...-brackets.html |
06-06-2017, 04:44 PM | #6 |
i mean a 5.7 vortex mounts high on top anyway so you should be good to go on that
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-06-2017, 06:45 PM | #7 | |
06-07-2017, 10:53 PM | #8 |
Senior Moment
Correct me if I'm wrong but I don't think that's a 5.7 you have pictured?? At least it doesn't look like mine. It's out of a 2002 Firebird
06-07-2017, 10:56 PM | #9 | |
Senior Moment
06-07-2017, 11:34 PM | #10 |
That's a Vortec truck engine, it's a Gen1 small block. Those accessories won't bolt to an LS.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-08-2017, 12:31 AM | #11 |
I just installed the Holley this evening. Worked well. I am running the corvette style accessory drive and obviously can't run the AC low.
I like the looks. It matches the rest of the GM natural aluminum. |
06-08-2017, 02:09 AM | #12 |
Senior Moment
Pics Please, still trying to make up my mind
06-08-2017, 10:12 AM | #13 |
No compressor yet.....But here's what it looks like.
06-08-2017, 11:51 AM | #14 |
Senior Moment
Very nice
Thaks
06-09-2017, 10:12 AM | #15 |
I used a set from LS brackets http://lsbrackets.com/ on my wife's truck. It is a 1987 R10 with '04 GTO LS1. I wanted to be able to use factory a/c lines, which are for a 89-91 suburban and worked perfect. I know the R4 is not a desirable compressor, but it was cheap and works fine.
1972 Cheyenne C10 LWB 1970 C10 292 I6 3 speed 2017 Silverado LS 4x4 1978 El Camino SS, LT1 swap 2016 Camaro SS Last edited by splatrd; 06-09-2017 at 10:26 AM. |
06-10-2017, 12:00 PM | #16 |
I know you expressed Highmount only but something you should think about is a company called Allen Grove components has a passenger-side AC bracket designed for The stock low mount position with a sandon compressor that moves the compressor 3 inches closer to the block. I'm doing an LS swap on my '67 C 10 in the next couple weeks and I'm going to mock up mine and see if this will work. The bracket kit is reasonably priced at $175 complete using the original AC pulley on my truck engine.
Steve weim55 Colorado Last edited by weim55; 06-10-2017 at 12:06 PM. |
06-11-2017, 01:25 AM | #17 | |
06-11-2017, 09:56 AM | #18 | |
Steve weim55 Colorado Last edited by weim55; 06-11-2017 at 10:06 AM. |
06-11-2017, 11:48 PM | #19 | |
Senior Moment
Thanks Again
