Identifying Custom camper
On 69/70 trucks how would you identify a custom camper over a regular custom-10?
Posted via Mobile Device |
Re: Identifying Custom camper
Hello neighbor, best information is found on the original SPID located inside the glovebox, if it's still there. It will list the custom camper option. A lot of things could have happened through the years to deviate it from original. Fender emblems and door scripts saying custom camper will help figure it out also. The custom campers I've seen will also have extra wiring running along with your tail light wiring harness inside of frame rail from cab. The extra wring is for a camper on the bed or for a camping trailer. If you can post some pics, the guys on here can help you figure it out.
Michael ![]() |
No emblems left and spid is faded. Did have 2 trailer light plug ins but idk if one original.
![]() Join Date: Nov 2011
Aren't all Custom Campers C/20 3/4 ton?
Dale - ApacheIvan 1972 Chevy Custom/20 Custom Camper Highlander http://67-72chevytrucks.com/vboard/s...d.php?t=740479 Original Owner ** Do you have a 1972 Plaid Pickup?** |
1/2 ton custom campers are said to exist. I've only seen them in the C20/K20 models myself.
Drew3, it would be hard to tell without the SPID. Maybe someone else on here will know another way to check.
Michael ![]() |
![]() Join Date: Oct 2009
Yes, 1/2 to cc's do exist. Without a SPID and no nameplates (fender nameplates on a 69-71), it's not possible to tell for sure without a build sheet as the Z81 option only provided the nameplate if certain options were present (in other words, the presence of all the suspension stuff, even the camper mirrors and camper wiring do not make it a Custom Camper - only the Z81 RPO does). Are there any emblems on your FENDERS? Custom Campers in 69-71 had a fender nameplate - only 72 (chevs) had the Custom Camper script above the door handle.
Here's a CustomCamper10 ala 69. 70/71 would have same fender emblem. 66-68 has the CustomCamper in a box emblem and 65 had a one-off. Last edited by jocko; 06-09-2017 at 11:18 PM. |
Any ideas on reading a faded spid? Could anyone post a photo of a custom camper trailer light plug? Does it matter if a truck is coil or leaf spring?
#8 | |
![]() Last edited by jocko; 06-09-2017 at 11:32 PM. |
My 69 is a 1/2 ton (GMC 910, Canadian) It has the custom camper badge by the door handle. It is light duty all around, coil spring, 307/t350. I added power steering and brakes. The sway bar on the spid was seperate. I think I remember reading that it was a bit fancier interior. Mine has the saddle interior with the scroll work on the seats and door panels.
I think you got a trailer plug at the dealer and not from the factory
-Cody |
more - to your specific questions - yes, coil springs possible (standard). Snip below is from the 69 brochure.
Here is my spid. It does show cust-something- conv. Equip. Z-??and camper nameplate something ?81 at the bottom. I see now it does have HD front springs and HD rear as G50 but I thought that was for leaf spring? It is fairly legible for being so scribbled up
-Cody |
Cody, your last option, Z81, is what makes your truck a Custom Camper. The Z62 is Custom Comfort and Convenience, just the trim level option. G50 is an HD coil. G70 is rear leaf.
#13 | |
![]() Join Date: May 2010
A truck (mine for example) could have all the options required for the nameplate but not have the nameplate. The nameplate was a no cost option that had to be specified when the truck was ordered from GM. Frankly, I'm glad my CST doesn't have the Custom Camper nameplate that would have replaced the CST fender emblem. In my opinion "CST" trumps "Custom Camper" (and I know it could be a Custom Camper). Springs could be either coil of leaf. EDIT: I see there have been several responses since I started typing... Last edited by FirstOwner69; 06-10-2017 at 12:00 AM. |
#14 |
One more note regarding GMC, the fender nameplate from 69-71 is Chevy-only - GMC's had the door script before Chevy did.
#15 | |
I threw up a pic of the emblem just because it relevant.
-Cody |
#16 |
Will be Sunday before I can get a picture of the spid. Thank for the info guys.
#17 |
No emblems at all on the truck currently. Doesn't matter to me if it is a custom camper or not just trying to learn everything I can about the truck.
#18 |
This is an older photo I apparently took. Sorry about the shadow.
#19 |
Lol, that is a tuff one to read. I can make out a little but curious to see what the pros come up with first.
Michael ![]() |
#20 |
you weren't kidding! Wow - yes, looking forward to an additional pic of that. Can make out model number and paint, and partial bits, but a new pic would help - one without the shadow. Thanks for sharing!
I am seeing CE10934 (model #), Gauge package, White/Blue(?) I THINK it's blue... but that's about it so far. Last edited by jocko; 06-10-2017 at 09:46 AM. |
#21 |
Here is a new one. The stains and writing don't help😄
#22 |
Bump
#23 |
I tried myself to pull it into an editor to see if I could change some light values, contrast and other things.. I am not sure there is enough left to get the writing back..Maybe someone else with better tools can try..
#24 |
That was easy.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#25 |
I will try some different lighting and maybe mess around with my computer. The truck must of sat with the glove box open it's whole life.
