06-12-2017, 07:16 PM | #1 |
Engine decals
Can some of you folks with correct decals under the hood show me some pictures of proper placement, what should be and shouldn't be there. I have one original left on the radiator support to the right, talks about timing. What is the one on the drivers side inner fender well? Also I think I know what goes on the front of the air cleaner, but not sure what goes on the left side rad support and I have actually seen one next to the rad cap on some. Also on the original 4 seasons air compressor I see some labels with the red across the bottom and some with blue. Were there any stickers or decals on the hood? From what I can tell there were none on the valve covers or top of the air cleaner, just the side?
Also one last question, If I remember right, mine had a long oil fill tube with the rubber OIL cap on top. I see some with some without. I have a 350/350 setup like stock.. Thanks in advance for your help!
Dale - ApacheIvan 1972 Chevy Custom/20 Custom Camper Highlander http://67-72chevytrucks.com/vboard/s...d.php?t=740479 Original Owner ** Do you have a 1972 Plaid Pickup?** |
06-12-2017, 08:16 PM | #2 |
Re: Engine decals
To get you started, vehicle emissions sticker placed on top the LH inner fender.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
06-12-2017, 09:25 PM | #3 |
Re: Engine decals
Passenger side radiator support.
06-13-2017, 12:49 PM | #4 |
Re: Engine decals
My 72 has the coolant decal in the same spot. On the top of my head, one decal on top of the compressor & one decal on front of the air cleaner.
06-13-2017, 02:18 PM | #5 |
Re: Engine decals
...the decal mentioned that goes on the front vertical surface of the (stock) air cleaner should say "Keep your Truck all GM"
As for the oil filler tube: To my understanding, the tall oil filler tube mounted on the drivers side of the truck was typical on the trucks that came with air conditioning. The reason was that the a/c brackets covered the regular oil fill point on the passenger side valve cover...so it was shifted to the drivers side on the a/c trucks. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
06-13-2017, 02:26 PM | #6 | |
Re: Engine decals
06-13-2017, 03:46 PM | #7 |
Re: Engine decals
I just ordered these for my engine:
For air cleaner: https://www.opgi.com/cutlass/1969/de...ecals/D400495/ For big block valve cover: https://www.opgi.com/chevelle/VC00241/
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
