07-02-2017, 04:09 PM | #1 |
Vacuum source
Which is the better source for vacuum, from the carb or from the intake manifold? Or is there no difference?
07-02-2017, 04:16 PM | #2 |
Re: Vacuum source
For what purpose? For most everything it would be off the intake manifold.
For vacuum advance off the carb. The non timed port of course. |
07-02-2017, 04:20 PM | #3 |
Re: Vacuum source
There are different type vacuum outlets. It depends on what you are running it too to know which you need to use. Give your year model & engine size & what you want to send vacuum to & I or some other Stovebolters can answer.
George |
07-02-2017, 05:53 PM | #4 |
Re: Vacuum source
Engine is 350, bored .30 over with mildly aggressive cam. Main concern is vacuum to the power brake system.
07-02-2017, 05:57 PM | #5 |
20' Daredevil (Ret)
Re: Vacuum source
Intake manifold vacuum for sure.
