07-07-2017, 01:32 PM | #1 |
History of the C10 suspension
I'm sure there is a thread buried somewhere in here, but who knows about the rear trailing arm design? Who designed it, when and why? It is such a unique thing, how the arms are angled into the center of the truck.
My dad, who is notorious for over analyzing everything, is always perplexed by the design. But he got me thinking about it. The rear end will slightly shift side to side, but it moves like a pendulum. Maybe this actually helps handle turns, by shifting the wheel on the outside of the turn back ever so slightly, and the inside wheel forward. And for launching, the force from the wheels moves through the trailing arms to the center of the truck to push it, maybe another advantage over leaf springs. |
07-07-2017, 01:52 PM | #2 |
Re: History of the C10 suspension
I'm interested to see the responses to this one myself. I don't have much to add, other than this bit from the 1972 trucks flyer --
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
07-07-2017, 04:06 PM | #3 |
Hmmm - never thought about those merits, but it's worth considering. I just know it rides gooood.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
07-07-2017, 04:13 PM | #4 |
Wonder why the brochure talks about the rear end, but illustrates a front end with steering linkage?
07-07-2017, 04:43 PM | #5 |
Oh, I just cut out a small part of a big picture.
07-07-2017, 06:36 PM | #6 |
Don't know who designed it, but, more of why it was designed, a smoother ride. First appeared on 1960 2wd 1/2 and 3/4 ton pickups, but 1 tons continued to use leaf springs for heavier duty work. The coil system you see on 67-72 Chevy pickups is basically the same system that was introduced in '63 ( see photo ).
07-07-2017, 07:40 PM | #7 |
OK. I thought it was a result of a Three Martini Lunch corporate culture in the Ad Dept...
07-07-2017, 07:42 PM | #8 |
I think Nascar uses the same basic design, if I'm not mistaken I think some people have even used some Nascar style trailing arms on a C10
07-08-2017, 07:16 AM | #9 |
Six in a row makes it go...
Yeah - it's my understanding that NASCAR has used the trailing arm rear suspension for quite some time. I also remember seeing a kit that would let you put them under your Chevelle too.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
