Got a 1960 ? on motor mounts
Starting a new project have 1960 short bed apache 10 torsion bar front end ,it has a stock v-8 motor mount (pictured ) never seen on like this ,,but looking for six cylinder motor mounts anyone got a picture of a 6 cyl mounts ? thx
Hop ![]() ![]()
Save a tree support your local drag strip !!! |
Re: Got a 1960 ? on motor mounts
That horseshoe works for both v8 and six.
The six is longer--it moves to that tab in front of the crossmember.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
Your truck has the six cylinder motor mount perch riveted on the front of the crossmember, (it must've had a six originally). you need a horseshoe for a six cylinder to sit on top of that perch, they are not the same as the v8, here is the comparison. The v8 is to the left (the one that is sitting on top of your crossmember) and the six cylinder horseshoe is on the right. As you can see the v8 one is a true horseshoe shape, but the six horseshoe leans to one side. Unfortunately finding this piece won't be too easy, it only came on 60-62 six cylinder trucks, and in order to remove it from the engine the harmonic balancer and timing chain cover needs to be off of the engine.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
Thanks a lot guys I was wondering I had 61 before and I didn't remember that extra tab in front of engine sub frame I was just about to ask the forum what that piece was for ,,,what's the chances on finding one of those ?
I thought for sure they were the same, with those extra holes in it for the mounting holes on the engine.
My '62 suburbn was originally a v8 truck, and had the tab ahead of the crossmember.
Which 6 are you planning on using.... The 235 style that came stock, or a later model 230/250/292 style?
I am putting in a 1970 - 250 thx
the other holes are for the 348. I would say you will need side mounts for the 230.
1961 chevy K10 my build is------------61K10 build |
that's what I thought side mounts wonder if a 63-66 inline 6 mounts can be modified to work on the torsion bar frame ? thx for your help Hop
Really?? I'm planning on putting a 348 in my suburban... I wonder if I can use that tab on front of the crossmember...
Do a search for 1960 motor mounts. a bunch of info.
if you have the horse of course. No body re-poes the rubber mount. If you have one i think steel rubber comp will re-vulcanize the org.
#13 |
If you're going to be using a 250 then why not just use side mounts with a 1/4" spacer on top of the frame rails?
#14 | |
#15 |
I did send you a pm on july 26
ron |
#16 |
If any (like me) want to have or keep something that's a little different than what most people have, then this is the closet to "new" motor mount t for the horseshoe I have found.
https://www.steelerubber.com/motor-m...ice-70-1828-11 Someone has said on this thread or another to look here but this is the direct like to the page you need. I have searched for about 5 years for a new center motor mount and have NEVER once found one. This is quit literally the best anyone company can do. I have yet to get mine done but I'll be having it revulcanized when I'm ready for it though. |
#17 |
Moderator
![]() ![]() Join Date: Aug 2011
This one doesn't work? - https://store.fillingstation.com/det...UNTREVULC.html
Also the filling station sells the one above - https://store.fillingstation.com/det...nGdFCJn429tJiI.
