Old 07-21-2017, 12:38 AM   #1
Double_C
Porterbuilt 1963 to 1972 C10 Stage 2 Rear Deluxe Coil-Over
Brand New PB Fab rear suspension all Powder-coated Satin Black and ready for install. Shocks have been dyno-tested and matched. Lowest installed ride height without needing to modify or raise bed. This kit is designed to be used with a single driveshaft, not the 2 -piece style (NO failed Center bearings again). Completely bolt-in kit, no welding. No additional time to paint your parts and verify functionality, this kit is ready to install.
This kit will improve the handling and look of your truck, approximate drop in height of rear is 6” to 7”.
Kit Includes
• Center Cross-member with adjustable pick points to adjust Instant Center and Roll Over Steer
• Tubular Control Arms w/ Threaded Rod Ends
• Adjustable Panhard bar w/ Roll Center adjustment based on Ride Height
• Ridetech shocks with adjustable rebound (Dyno tested and Matched)
• Hypertech Coil Springs
• Upper and Lower Shock mounts
• C-Notch Kit
• 2 rear frame Cross Members
• Fasteners and Hardware
$1900.00 OBO, does not include shipping, located in San Jose, CA. Call Chris to purchase and/or with any questions. (408) 219-8235
Double_C is offline   Reply With Quote
