Serpentine Belt
Has anyone use and after market serpentine belt kit on there C10 is so what kind how you like it any picture out there
Re: Serpentine Belt
GM sells them without the bling , best buy id say, if goin new
Stan 67 swb BLU MULE posted via flip-fone |
Re: Serpentine Belt
I bought this March setup about 15 years ago. Just got the engine started for the for fist time last fall. There seems to be some minor vibrations issues. Nothing that can't be fixed. Just waiting to get the truck back from painting so I can work on it.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
Its a Truck Thing......
Re: Serpentine Belt
Here is my GM set up with part numbers.
http://67-72chevytrucks.com/vboard/s...d.php?t=468729 Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
Re: Serpentine Belt
Pull a complete setup from a wrecking yard for less than $100. Looks and works great.
Re: Serpentine Belt
The serpentine belt setups from 89-95 5.7, 5.0 and 4.3 will work just fine and are readily available and local salvage yards. Make sure to get a reverse flow fan and water pump because the factory belt will spin the water pump pulley backward from what your truck was. Don't forget the pulley for the dampener and power steering pump while you are searching. Higher output alternator was nice to add while I did mine. Pictures were from before I did the 5.3 4l60e swap. I was very amazed how much different the engine sounded after the upgrade.
'70 C10 Short Wide 5.3 4L60E 2wd 3.73 W/Locker '69 C10 Short Narrow 5.3 4L60E 4x4 3.73 on 01 Tahoe Frame - work in process |
