07-24-2017, 07:49 PM | #1 |
Do you know this frame
Im in the middle of tearing down a 87 S10 for a frame swap for my 52 AD and yes if i had the original i would use it but i dont. Its pretty bad shape but the frame the truck is on is much better. It has a 116" wheelbase with a 62" 12 bolt rearend with a V8. Think I'm just going to use the frame its on. Anyone know what year the frame is?
07-24-2017, 08:33 PM | #2 |
Post Whore
Re: Do you know this frame
just a guess without some more pics,, but I'm guessing some kind of car frame based on the frame being pulled in behind the axle..what does the front half of the frame look like?
07-24-2017, 08:58 PM | #3 | |
Sory this is all i have |
07-24-2017, 09:05 PM | #4 |
The front end has been bolted into frame also.
07-24-2017, 09:17 PM | #5 |
It looks like a 63-66 or 67-72
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
07-24-2017, 09:30 PM | #6 |
Hollister Road Co.
If the rear springs are original then I'd say 71 or 72 GMC
Its definitely a 67-72 style frame |
07-24-2017, 09:53 PM | #7 |
Post Whore
here's one I found..believe this pic is a 72...
07-24-2017, 10:13 PM | #8 |
It looks like a 71 or 72 but mine doesnt have the cross bar at 90.2
07-24-2017, 10:23 PM | #9 |
Leaf spring trucks don't have that cross member.
07-24-2017, 10:45 PM | #10 |
07-24-2017, 11:15 PM | #11 |
Hollister Road Co.
12 bolt was half ton.
07-24-2017, 11:19 PM | #12 |
gmc's were leaf spring rears if I recall.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
07-25-2017, 12:48 AM | #13 |
Yep most GMC 1/2 and 3/4 for those years were rear leaf while most if not all. Chevys were rear coil.
I'd say 71/72 with the front disk brakes. A bit wide in the front unless you want to run a big truck nose or have the tires outside the fenders a tad.
