Old 07-30-2017, 12:49 PM   #1
suburban99
suburban99's Avatar
LQ4 to Turbo 350 kick down brackets with measurements.
Asked the question where and how to mount the kick down cable for the stock TH350 on my 1972 K10 LQ4 swap. Couldn't find much info so I made up a set.
Transmission is in stock K10 position so it's very tight to the firewall. This setup should work with a C10 as well. I used a 2" x 1/8" aluminum flatbar because it's easy to drill and tap and I had it in the scrap bin. I don't have a fancy machine shop so all brackets were made with a hand drill, a grinder, a dremel tool and tap and dies. Kinda ranch but it works excellent. Uses stock TH350 cable that was on the truck. Make sure you use short bolts (or grind to fit as I did) as fuel rail is directly below bracket. Hope this helps.
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 04-02-2018, 05:01 PM   #2
69BUCKET
Re: LQ4 to Turbo 350 kick down brackets with measurements.
Did you FAB SOMETHING up at the throttle for connection OF extension bar? Any better PICS OF that?
69BUCKET is offline   Reply With Quote
