69 c10 wont fire HELP!!!!
ok so im back ... my poor 69 wont fire it was fine 2 weeks ago. its a inline 250 with HEI i took the coil out and put a meter on it both the primary and secondary coil ar good. i have power going to the cap. ran i hot wire right to it from the batt just to make sure. wtf is going on. what should i check next . took a plug out had my gf turn the truck over as i grounded the threads no spark. what is going on? please please help me . i want back in my truck .
![]() Join Date: Jan 2001
Re: 69 c10 wont fire HELP!!!!
The center button on the HEI caps sometimes falls out. If it's not that I'd guess the module is bad.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Moderator
![]() Join Date: Jun 2017
There is a link below that details the conversion of standard to HEI...
http://67-72chevytrucks.com/vboard/s...d.php?t=148346 I know you have had an existing HEI i place...but this thread goes into a lot of detail about wiring and plugs etc... Especially check the plug on the firewall to amke sure you are getting correct voltage... ![]() ![]() ![]() |
