08-17-2017, 10:51 AM | #1 |
Junior Member
Barn door handle
Hi All,
Does anyone know where I might find a replacement handle for the barn door of a 66 Suburban? The old one I have is different than the side door handles... The pin is shorter, and the part of the handle that fits into the hole in the door sheetmetal is also shorter than the side door handles. I haven't been able to find a repop. I'd even settle for another year/style of handle that would work. Just wondering what others have experienced with this. I guess I could have the old one re-chromed and rebuilt, but it's a mess so I'm not sure how well that would work out. Thanks for any and all input!
Dave 1966 K10 Suburban |
08-18-2017, 10:50 AM | #2 |
Re: Barn door handle
i know where one is, if you need it i can go pull it.
08-18-2017, 06:19 PM | #3 |
Junior Member
Thanks man, but the chrome on that one actually looks worse than the one I have! I'll do more homework and see what my options are, but I may get back to you. Thanks!
08-22-2017, 07:26 PM | #4 |
I'm pretty sure the chrome handles are the same as the side doors. The lock mechanism is definitely different. I picked up a standard lock mechanism, for the side door, and just trimmed the push rod so it was the same as the original on the barn door. Works like a charm.
08-22-2017, 08:13 PM | #5 | |
Junior Member
08-22-2017, 11:49 PM | #6 |
I have one
ron |
08-23-2017, 01:26 PM | #7 |
Junior Member
Hi Ron, thank you. Can you tell me if it is the same as the side door handles? If it is, I'm good, I have an extra side handle that I can use. If yours is different and in good shape, I may be interested in it. Thanks again!
08-23-2017, 01:30 PM | #8 |
I don't know. the doors are at a storage facility that i have
ron |
08-23-2017, 09:15 PM | #9 |
Where did THAT bolt go?
They are the same outside of the length of the shaft that actuates the door. You just need to trim a little off and they work like a charm.
The Swiss Car Club......A drinking club with a car problem.... |
08-25-2017, 02:32 PM | #10 |
Junior Member
Thanks for confirming that for me. I'll just trim the pushrod and test it out. Thanks again!
