Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 08-18-2017, 06:05 PM   #1
Pro Performance
Pro Performance's Avatar
Cowl Mounted Hood Hinges: 60-66 and 67-72
We are offering Switch Suspension cowl mounted hood hinges for your C10! Switch Suspensions Cowl Mounted Heavy Duty Hood Hinges Will Support Your 60-66 C-10 Hood With 3/8" Thick Hinge Arms Pivoting On MDS Filled Nylon Bushings & High Stregth Shoulder Bolts For Accurate & Smooth Operation. Weld On Hood Mounting Plates Come With Pre Welded Nuts For Hassle Free Hood Installation. Precision CNC Cut & Tig Welded HRPO Steel. Made In The USA.
Gas assisted for easy operation and no hood prop needed! All products are black zinc coated.
Includes:
- Cowl Mounted Hood Hinge Kit (pair)
- Gas Struts
- Weld On Hood Mounting Brackets (pair)
- Mounting Hardware
$400 For the Set
Pro Performance is offline
Old 11-20-2017, 12:34 PM   #2
russellrox
Re: Cowl Mounted Hood Hinges: 60-66 and 67-72
Any reviews on quality compared to pb fab?
russellrox is offline
Closed Thread
