08-21-2017, 03:41 PM | #1 |
Super nice misc parts
All parts where removed from a 71 2wd v8 350 truck real nice fan shroud no cracks or brakes great color no fading $100.00 - original fan shroud hardware $20.00 - clean ash tray $20.00 - 2 barrael air cleaner spacer $20.00 - 4 speed shifter boot & ring with original screws boot is soft with no cracking $45.00 - horn contact hardware $30.00 - coil bracket & original bolts $20.00 complete set of steering column brackets with all bolts & screws $55.00 - nice tight clean floor shift column with original turn siginal switch $125.00 - clean & complete manual throttle control set up cable moves free with all bolts & hardware $150.00 all parts are plus shipping - first i will take it gets it ... Thanks
08-21-2017, 03:44 PM | #2 |
Re: Super nice misc parts
More pictures
08-21-2017, 03:52 PM | #3 |
More pictures
08-21-2017, 03:56 PM | #4 |
Pictures
08-21-2017, 08:50 PM | #5 |
One of the First
Ill take this: original fan shroud hardware $20.00
08-22-2017, 07:41 AM | #6 |
I'll take the throttle, the column, the 2 bbl spacer, Can you do better on the steering column brackets and bolts since I'm taking the column?
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process |
08-23-2017, 08:39 AM | #7 |
Fan shroud hardware "sold" thanks
08-24-2017, 06:25 PM | #8 |
08-24-2017, 09:19 PM | #9 |
Is the fan shroud for an A/C cab truck?
08-25-2017, 08:34 AM | #10 |
No this was a non a/c truck
08-26-2017, 02:53 PM | #11 |
Steering column - column brackets - carb spacer - throttle control asmp are "sold" thanks
08-28-2017, 03:06 PM | #12 |
Ttt
