08-29-2017, 10:11 AM | #1 |
overdrive manual transmission options?
Hello,
To my knowledge, there are three good options for an overdrive manual trans. 1. Ranger overdrive coupled with sm420/ sm465 2. Nv4500 3. T56 with midshift kit. I didn't include the gear vendors, only because at $3k, it's a little out of my price range. And I wouldn't consider the nv3500 due to durability issues. Am I missing anything? Out of the three options I listed, what are the pros and cons? what has worked the best for you?
2012 GMC 2500hd/ 6.0 1972 Chevrolet c20 350/350 1986 Chevrolet Monte Carlo SS/ 6.0 lsx |
08-29-2017, 11:10 AM | #2 | |
The Older Generation
Re: overdrive manual transmission options?
This is how I replaced my SM465 with an NV4500 in my '72 Chevy Dually. http://67-72chevytrucks.com/vboard/s...d.php?t=673588 That was in 2015 and it is still working great today.... LockDoc
08-29-2017, 11:57 AM | #3 |
I'd go with the NV4500, the NV3500 is a good transmission if you are not using your truck for too much work, it is a medium duty and only rated for 300 ft/lbs
I wouldn't bother with add on overdrives the seem expensive for what your getting and unless you really want to keep your transmission that you have already. |
08-29-2017, 12:39 PM | #4 |
Define "good options"
4x4 selection is really limited. 2WD less so. You left off the T-5 and the A-883 (which was available with an overdrive). Also there are a few aftermarket solutions. edit: I didn't see that you put the NV3500 in the bad option list so the weaker T-5 would also be out.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
08-29-2017, 01:51 PM | #5 |
Post Whore
Here is a good site for some research on the subject.
https://www.novak-adapt.com/knowledg...ssions/manual/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-29-2017, 02:50 PM | #6 |
I'm a huge fan of the New Process A-833 (RPO MY6).
250,000 miles on mine with no issues. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-29-2017, 03:18 PM | #7 |
Well I'm certainly happy I started this thread, I've never heard of that transmission. Thanks know you much!
08-29-2017, 03:42 PM | #8 |
I have a TKO600 and I'm not very impressed with it. the case leaks a bit from the factory (I bought it new), it's kind of noisy in 4th, and the 1st to 2nd shift is slow and cumbersome. Maybe I got a lemon, who knows. I do like the 5th gear overdrive, it's smooth and quiet.
For reference, I have this installed behind a BBC in a 66 2WD |
08-29-2017, 04:01 PM | #9 |
The TKO 500 is a good option, the 1-2 ratio split seems like it would be good for most uses and the overdrive is fairly steep.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
08-29-2017, 09:24 PM | #10 | |
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
08-29-2017, 10:09 PM | #11 |
Is there an overdrive available for a 3OTT? I love my column shifter but could use another gear (or two).
08-29-2017, 10:45 PM | #12 | |
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
08-30-2017, 06:17 AM | #13 |
From what I read, it was used in Chevy trucks from 81-87 in 2 and 4 wheel drive. And yes, it was a true 4 speed with an overdrive. Rpo code my6. But the a833 was originally used by Chrysler in the 60s
08-30-2017, 07:31 AM | #14 |
It's three forward gears plus the overdrive.
It is a MOPAR trans with third gear set 1:1 and 4th gear as .73:1 (or .70:1 - I never can remember). The factory shifter was provided by Hurst. Mine is an '87, and I ordered it specifically. K
08-30-2017, 07:43 AM | #15 |
HI keith, I'm assuming that it also uses a mechanical speedometer drive? That would be having my cake and eating it too
08-30-2017, 07:46 AM | #16 | |
08-30-2017, 09:13 AM | #17 |
Pics of the mY 6 are here, it has a mechanical speedo
https://67-72chevytrucks.com/vboard/...=574221&page=5 |
08-30-2017, 01:44 PM | #18 |
Mine has a mechanical speedometer.
K
12-21-2021, 10:38 PM | #19 |
Possibly, I just finally found a Borg Warner overdrive with the Rancho adapter on it for the Dana 20 transfer case in mine. If yours has the Dana 20 then you can start searching for one of these. It's old stuff but I really want to keep the SM-330 column shift so this was the only option. Rancho sold them for Jeeps, Broncos, and Scouts. It uses either the B-W R10 or R11 overdrive. Only works in 2wd.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
12-21-2021, 10:51 PM | #20 | |
12-21-2021, 11:13 PM | #21 |
This thread is older than one of my jokes, but I'll throw my two cents in.
I recently installed a Gear Vendors Overdrive and love it.
12-21-2021, 11:27 PM | #22 |
I feel into the time warp, hook, line and sinker! Ha.
12-22-2021, 09:48 AM | #23 |
Yeah I knew the comment would come up on a four-year old thread but I was searching around, found this thread and saw that the one question wasn't ever answered so I threw my two cents in as well. I am super excited about finally finding one of these rare items so that my Blazer isn't screaming keeping up with modern traffic.
12-22-2021, 11:09 AM | #24 | |
12-22-2021, 01:46 PM | #25 |
I want an A833 for XMAS, or next XMAS.
