09-14-2017, 09:54 PM | #1 |
Adapters for c5 fuel regulator
What are part numbers for c5 regulator to AN6 line? Using Ptfe hose and a 3/8th" hard line down the frame rail. Finally getting to work on my '67.
09-14-2017, 10:30 PM | #2 |
Post Whore
Re: Adapters for c5 fuel regulator
c5 regulator? ...is this the commonly used vett filter/reg with pushlok fittings.?
09-14-2017, 10:48 PM | #3 |
Yes, the corvette filter/regulator. I bought kit from summit,but it's incomplete. The line to the filter from the pump has a barb, but I'm unsure of the fitting for it.
09-14-2017, 11:33 PM | #4 |
meowMEOWmeowMEOW
It should be GM Quick connect no? 3/8 feed, 5/16 on the return from the reg to the tank.
If your going to AN, then its a 3/8 Quick Connect->-6 male AN. The other one is 5/16 Quick connect->-6 male AN. The female side of the regulator accepts the 45* flare hard lines for fuel. Summit and Jegs both carry the common Russel or Earls versions of what your looking for.
09-14-2017, 11:38 PM | #5 |
Post Whore
^^^^yep....brew beat me to it...^^^^...be sure you plumb it up correctly. .
