09-17-2017, 09:43 PM | #1 |
4x4 Exhaust Manifold
WTB Dr side 4x4 exhaust manifold
09-17-2017, 10:17 PM | #2 |
Re: 4x4 Exhaust Manifold
John, I have a couple but not sure of the part numbers. Looking for anything specific by # or just a center dump small block exhaust manifold? Pretty sure I have at least one that also has the threaded accessory portion which is on the driver side. Will look tomorrow thru the stash and see what is there for sure.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
09-17-2017, 10:38 PM | #3 |
No certain number just one that will work .
09-18-2017, 05:06 PM | #4 |
John, pic of the three spare center dump exhaust manifolds I have. Two are actually LH with the early style generator mounting I mentioned. One is a RH but with the center dumps they can be used on either side.
The top left is a 2'' #3733976 '57 Vette (True Vette manifold, LOL) The top right is a 2'' W/AIR tubes for 327-350 '67-'71 Chevelle #3872766 The bottom is 1.9'' with/AIR tubes for '66-'68 Chevelle, Pass Car or Truck California required Air Injection Reactor I believe it was called or just AIR tubes. All have good solid metal with no cracks, look to have useable studs but I would change them while they are out and in the open. The two uppers would need the mountings ground off for a cleaner looking install if not needing the mount holes. Bottom manifold has had two holes welded closed, two still open. I planned on welding and grinding smooth if I needed to use this one at some point. Been keeping these just as a possibility of need but don't really need all three. I did replace a cracked exhaust manifold about 15 years ago so guess I don't really need three spares, LOL. Would like $30 each plus shipping if any of these interest you. LMK, if not what your looking for this is best I can do. Nice clean center dumps are getting harder to find around my neck of the woods.
09-18-2017, 05:42 PM | #5 |
The bottom one looks like what I currently have and I will take that one if you can get me a shipped price . And I will need your address again and hope a money order still works for you .
Thanks John |
