09-19-2017, 09:43 AM | #1 |
Coil Relocation LS3
I found some room to re locate my coil pack
I believe that the wiring pack for the coil banks have a 1357 and 2468 So turning them upside down and backwards will confuse the ECM Can I move the whole coil and wiring+bracket from bank1 and and bank 2 to opposite sides? The question I have is I know there is a bank 1 Driver side and bank 2 I can "flip" the bracket upside down for mounting on the inner fender well BUT that will place the number 2 coil on number 8 spark plug This whole operation will only cost the addition of a 24" coil extension wire and plug & play and the plug wires are long enough, so no change there/
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
09-19-2017, 08:44 PM | #2 |
Re: Coil Relocation LS3
Coils are not cylinder or bank specific. All that matters is that the trigger wire matches the plug wire. In other words, the trigger wire for cylinder three goes to the coil that feeds current to plug #3.
I relocated mine to the inner fenders. The intent is to eventually stick some cooler valvecovers on the engine. |
09-20-2017, 12:00 AM | #3 |
Thanks....... Got It
Yes that is my objective also I think just milling the nubs off the valve covers will increase the looks by by 75% After that I am sure there is something I can do to them beside painting them ! Where did you get the 24 inch extension cable for the coil pack?
09-20-2017, 12:06 AM | #4 |
Post Whore
I read somewhere that milling those nubs off the valve covers adds like 10-15 hp...........hehe...
but you could use a set of ls to sbc valve cover adapters and then use sbc covers..lots of choices in sbc covers...I'm thinking about trying to adapt some 348/409 covers for my ls3...I've been thinking a lot on how to make it work and look right..without looking out of place... Last edited by mongocanfly; 09-20-2017 at 12:15 AM. |
09-20-2017, 12:19 AM | #5 |
I tried that, and yes it looks great, but the oil fill and the PCV you must be more creative than I!
09-20-2017, 07:33 AM | #6 |
I didn't use an extension. I made my own engine/PCM harness. The coil wiring splits off back at the transmission and runs up the frame rails.
09-21-2017, 02:06 PM | #7 |
hey have you had any issues with that ICT billet power steering bracket? I have one on a swapped firebird and its already broken a bolt once and flexes like no other. Also the the pulley alignment leaves a lot to be desired. Just curious if you have had issues as mine has shredded a few belts.
09-21-2017, 02:43 PM | #8 | |
I bought there set up for a mock up and have not started that engine The new LS3 I have I bought the DirtyDingo brackets and everything lines up and the belt runs straignt
09-22-2017, 06:57 PM | #9 |
If you mill the coil mount bosses off the valve covers they leave the bottoms of the threaded holes visible. They will need to be filled in with something.
09-23-2017, 09:22 AM | #10 |
Your right !
I found that out yesterday when I started cutting them off !! I will find a Tig welder!
09-23-2017, 04:46 PM | #11 |
09-23-2017, 07:46 PM | #12 |
It looks like they give you "filler" bolts that hold down the coil pack!
I am just going to screw the double "bolt" back in the blind hole and trim them off to the surface of the cover That was nice of them to provide filler bolts !! I do like the J B Weld also, we will see which one takes less time !
09-23-2017, 09:50 PM | #13 |
The big brown truck dropped off my 24" extension, Plug and Play, done ,that was easy !
09-25-2017, 01:12 PM | #14 |
