Old 09-19-2017, 02:22 PM   #1
dgheinen
1994 4L60E from a Chevy C1500?
I have a chance to buy a 2wd 4l60E from a 1994 Chevy C1500. If I buy this, will it work with a 5.3? I haven't yet sourced the motor, so I don't know what year it will be.
dgheinen is offline   Reply With Quote
Old 09-19-2017, 02:57 PM   #2
Bigdav160
Bigdav160's Avatar
Re: 1994 4L60E from a Chevy C1500?
I think you can make it work with a crankshaft adapter.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-19-2017, 03:25 PM   #3
dgheinen
Ideally, I'd like to use this on the 350 I have now, and be able to use it again when I get a 5.3
I understand I won't be able to use the top bolt if I put this on an LS motor, but I've read that it shouldn't be much of a problem. Do you guys see any downside to using the crank adapter?
Old 09-19-2017, 05:34 PM   #4
Bigdav160
Bigdav160's Avatar
There are some electrical differences between the early models and the later model transmissions.
I have no idea if using non PWM trans with a PCM that wants a PWM torque converter clutch will be a problem
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 09-19-2017, 07:41 PM   #5
clinebarger
Non PWM 4L60E's do not play well with LSx PCM's. Also the 3-2 downshift solenoid & the 3-2 hydraulics are different in 93/94/95 valve bodies.
You can swap in a 1996 & up Valve Body & disable the PWM function with a Trans Go TCC Regulator Valve......Comes in the SK & HD2 shift kits. Sonnax also has one in their shift kit but pretty expensive.
Like Dave alluded to.....A Paper TCC clutch lining will not last long with the PWM apply functioning.
You can also tune the PWM out with tuning software.
It's probably in your best interest to find good 300mm 4L60E!
clinebarger is offline   Reply With Quote
Old 09-19-2017, 08:43 PM   #6
dgheinen
Bummer! I was really hoping to be able to put an overdrive trans in now and have it work with an LSx motor too when that time comes. I'm glad I asked, and I'm really grateful for the help!
Old 09-19-2017, 11:19 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
It would probably better to just sell the motor and trans together that you pull out, and use the cash for the new 300mm 4l60e (or get a 4l80e ) when you do the swap.
Paired motor+trans usually sells better on craigslist/online because people know the components already work. Buying a trans alone used is the like the most nerve racking thing haha.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
