10-28-2003, 12:02 PM | #1 |
Got big-block?
anybody need parts off this 250 6-cylinder?
It's out of my donor truck. Was running. Not sure of year.
Has 3-bolt outlet exhaust manifold ($40 + ship), and HEI distributor ($20 + ship). Email me at carpediem_00@yahoo.com - please, no pm's - if you need any other parts off it. Last edited by superchevy; 10-28-2003 at 12:04 PM. |
10-28-2003, 12:03 PM | #2 |
Got big-block?
pic2
10-28-2003, 12:04 PM | #3 |
Got big-block?
pic3
10-28-2003, 04:58 PM | #4 |
Active Member
250 / 6
I dont think that my Email is geting out to you
I want if it will fit a 292 the exaust manifold, do you know if it will Also I need the front and rear motor lift out brackets Did this truck have power sreering? If so I want it too |
10-28-2003, 06:20 PM | #5 |
The 292 mainofold will be the same the only difference is on the inside. I use't race 6cly back in the late 70's and we ran 6bangers and we always wanted to run the 292 mainofold on our 250 engines.
How much for the carb. 29720?
Things happen for a reason! |
10-29-2003, 10:09 AM | #6 |
Got big-block?
Exhaust manifold and lift brackets are sold.
Big Orange, $5 + ship for the carb. Let me know, SC |
10-29-2003, 07:03 PM | #7 |
Got big-block?
HEI is sold. Thanks.
10-29-2003, 07:33 PM | #8 |
Active Member
250 / 6
Does the thermostat housing come it two parts top & bottom?
How much for it? P.S. I sent out the first payment. |
10-29-2003, 08:03 PM | #9 |
Got big-block?
I'll check the thermostat housing tomorrow.
10-29-2003, 10:58 PM | #10 |
PM me a total on shipping 29720.
thanks SC
10-29-2003, 11:31 PM | #11 |
Was this a auto trk? can't quite see.. needing a dedent set-up for a 70, type with a rod throttle.
Thanks |
10-30-2003, 02:37 AM | #12 |
if it was a cable type throttle i need the detent cable bracket and the modulator valve line.
i survived cancer and kidney stones, but my kids are killing me. |
10-30-2003, 10:28 AM | #13 |
Got big-block?
This truck was originally a 327/t400 truck. T400 is still there, but the 327 was pulled at some point, and this 6 cyl swapped in.
Look closely at pic1 of the engine. See the thin grey wire attached to the bottom throttle arm of the carb? That's the "linkage" LOL to the rod attached to the pedal. I know you don't want the wire, but the rod and the other parts attached to the pedal? Just trying to make sure I have what ya'll are looking for. SC |
