Old 10-01-2017, 11:42 AM   #1
Lookin4the1
4l80e acting funky
I've got a 6.0 with a 4l80e. I've put about 600 miles on it since the swap and it wants to shift at odd points or too soon into overdrive or 4th. it will also downshift itself out of no where. when i start out in OD. I've just been manual shifting and going through the gears and usually leaving it in 3rd unless i'm 60MPH. do i have a bad VSS sensor?
I'm trying to get it tuned next week, but theres no point if the trans is acting all crazy.
Lookin4the1 is offline   Reply With Quote
Old 10-01-2017, 12:13 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 4l80e acting funky
Not true. If the issue is happening because of a tire size problem, or lockup/shift settings that don't gel with your rear end and tire size, then you can get all sorts of shifting issues.
Are you getting any codes indicating a mechanical failure?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-01-2017, 12:24 PM   #3
Lookin4the1
no codes thrown at all.
Old 10-01-2017, 01:43 PM   #4
ls1nova71
ls1nova71's Avatar
This. It sounds exactly like you don't have the correct rear gear and/or tire size. Get a tune and let us know how it is.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-03-2017, 10:52 PM   #5
Lookin4the1
The best money I've spent on this swap so far. I never would have thought that a simple street tune would turn this truck around. The tuner said every setting on the trans was absolutely wrong and whoever tried to tune it before was an idiot. The trans actually shifts soft and smooth and when I accelerate it acts right.
Old 10-03-2017, 11:11 PM   #6
mongocanfly
Post Whore
mongocanfly's Avatar
glad to hear your shifting now..did you also get your engine dyno tuned as well? ...that'll also be money well spent
Old 10-03-2017, 11:34 PM   #7
Lookin4the1
They just took it down the road for about an hour and played with it for drivability. I will probably put it on a dyne down the road.
