10-28-2003, 03:46 PM | #1 |
Hammer On!
Wood Bed ?
Well, im making progress on finishing this wood bed on my truck. I'm putting White Oak in place of the original wood and im needing to know what you guys used as a polyurethane. I've only found MINWAX's Helmsman. It protects against weather, UV and one other one that i can't remember. Anyway, if you guys could provide some info to help out id appreciate! Thanks!
Aaron
1968 C20 Inline 6 250 SM465 4 speed 1968 K10 Inline 6 250 SM465 4 speed |
10-28-2003, 03:55 PM | #2 |
I was told to use a Marine polyurethane. It is supposto be the best.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
10-28-2003, 09:00 PM | #3 |
A marine grade spar varnish is supposed to be better than urethane for UV resistance. Haven't gotten that far with my floor yet to get the facts.
69 GMC K10 ..some restoration required....still.. |
10-28-2003, 11:40 PM | #4 |
Hammer On!
My dad was mentioning something to me about if i go with a marine grade, it might not allow the wood to breathe as well as it should. He was thinking along the lines of a sealant from water and UV but still allow it the air. I guess he was thinking of something like Thompson's Water Seal but not quite. I don't know, ive done some searching on the net but haven't found much and im not surprised. Most of what i have found in the stores isn't going to work as it will just end up peeling off in a year leaving me in a fit of rage. Oh well, back to the search engines!
Aaron
10-29-2003, 01:22 PM | #5 |
One more reason to mourn the loss of Penta to over-regulation. . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
10-29-2003, 02:07 PM | #6 |
Semi-Senior Member
From what I was able to learn, no matter what finish you use, you'll have to redo it maybe once a year. Unless...............it never sits outside in the sun, or has any bad weather hit it.
Otherwords, it sucks if you plan to drive it. Steve
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
10-29-2003, 03:50 PM | #7 |
My other Love
I stained my oak boards, and every year I just re oil, might be better to polyurathane them, one of my board has gone a bit punky on the edge, oh well
MEMBER DISCS UP FRONT CLUB
Hooter_5@hotmail.com AC/DC RULES!!! First generation Monte Carlo club pictures of my life |
10-29-2003, 04:20 PM | #8 |
Hammer On!
Sounds like im pioneering into this woodbed issue... seems not many people know for fact what works best. I must be too young to know what Penta is... never heard of it. Good stuff was it? Oh well ill keep ya posted
Aaron
10-29-2003, 06:23 PM | #9 |
Ok, guess I'm gona have to date myself here. THE BEST wood treatment for wood that's out in the weather is:
25% Terpentine and 75% Boiled Lindseed Oil This was used on wood Floors, Axe, Shovel and Hoe handles as well as Military Gun Stocks, Corral Fences and Gates. If you add OX blood to it you have barn paint, that's where red barns came from. We've used it on every wood floor we've had and in 6-8 months it'll turn Pine as hard as Oak. Easy to use, every 4-6 months just mop some more on and let it set for an hour. Whatever doesn't soak in just wipe off. It won't give you a high shine so if that's what your looking for go the polyurthane route. But if your just looking for a durable finish Terp and BLO can't be beat. |
10-29-2003, 07:10 PM | #10 |
i'm thinking about trying "trex" which is a wood manufactured from recycled wood and plastics. not sure if i can rip to size though. probably will cost a fortune.
10-29-2003, 07:19 PM | #11 |
According to Bruce Horkey at Wood and Parts, one of the premier wood floor replacement vendors, they supply a finish kit with each floor. It consists of "Old Masters" brand Tung Oil Spar Varnish, reduced with Nel-Thin-Ol, to give better flow properties. They sell the finish in a complete kit, with everything needed to prep the wood, and apply the finish. Phone # 507-831-5625 Fax# 507-831-0280 or e-mail woodandparts@yahoo.com Be sure to ask for the catalog, as it has all their products, and prices in it.
10-29-2003, 09:55 PM | #12 |
Trex is great, I use it all the time for decks but your going to be doing a lot of resawing to get it to thinkness. You don't want to run it thru a planer, planer knifes don't like the plastic. At 3/4 thickness the stuff is short on stiffness. It will have too mush bend in it.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
10-29-2003, 10:27 PM | #13 |
Ripped my floor out today I'm going back with cedar to match my custom interior treated with boiled lindseed oil .
10-30-2003, 12:07 AM | #14 |
Semi-Senior Member
We have bought plastic sheeting for Numberoneson's truck. It is a sand finished black product that comes 3/4 inch in thickness. We will rip it and rout the edges to fit. Unless i have figured wrong, we will get all we need out of a 4x8 sheet.
I have a friend that owns a truck bed manufactuerer that got it for us. We think that a red shortstep with stainless strips will look real good. Steve
10-24-2017, 04:33 PM | #15 |
But Found Her 25yrs Later!
Re: Wood Bed ?
Bump
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-25-2017, 08:02 AM | #16 |
Re: Wood Bed ?
Mar-K manufactures a lot of stuff for trucks. They have an excellent write up on their website detailing different wood finishes. I recommend a complete reading before making a choice.
Additionally, this has been gone over many times on this forum. Run a search here, you will find the subject several times. An interesting option is KBS Diamond Clear. It's a clear epoxy based finish, very similar to POR 15 in performance, but extremely glossy, UV stable, and clear. Stain the wood, then either brush it on or spray it on. Thins out and flows very nice. High gloss, looks like automotive clear. Again, I recommend checking the Mar-K website and doing your own research. |
10-25-2017, 08:12 AM | #17 |
Re: Wood Bed ?
Here is the stuff I used and I apply it every 6 months.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
10-25-2017, 08:53 AM | #18 |
Re: Wood Bed ?
I believe Helmsman poly is marine grade. I figure that's why it's called helmsman.
I personally don't like the idea of any hard finish like poly on a bed floor. You want something that "gets into" the wood, not lay on top like paint on steel. One scratch and the seal is broken. Only way to fix is sand out and re-coat. I use oils on exterior wood. Good old linseed oil and mineral spirits or turpentine is a great protector. I have also thinned down paint to a stain consistency, then a clear preservative oil or linseed/turp
10-25-2017, 10:59 AM | #19 |
Re: Wood Bed ?
We used Epiphanes - wonderful product..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
10-25-2017, 05:22 PM | #20 |
Re: Wood Bed ?
The first 14 posts were from 2003 but good
Information |
10-25-2017, 05:25 PM | #21 |
Re: Wood Bed ?
Yes, I bumped the thread because it was a question in another thread.
10-25-2017, 10:02 PM | #22 |
I am a Referee of life.
Re: Wood Bed ?
For a glossy show bed, I would look into the marine grade epoxy. The type they use on Cedar strip canoes. For a truck I was going to drive, BLO and thinner so it would soak in better. I would probably use a 25% BLO/75 thinner for first coat and then a 75%/25% second coat and allow it to soak a while before wiping.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
