Old 10-19-2017, 01:56 PM   #1
Steelydan
Steelydan's Avatar
Rear differential
I am in the process of a frame up restoration, what is the best way to do the rear differential? Attach it all back the frame and then install the axles and third member? Or put it all together then attach it to the frame?
Steelydan is offline   Reply With Quote
Old 10-19-2017, 02:39 PM   #2
B. W.
B. W.'s Avatar
Re: Rear differential
IMO, depends on if you have a lift or not.
Without a lift, if it's off the frame I'd prefer building it on jack stands or a bench. Beats crawling under the truck.
If the truck is on a lift I'd rather build the axle on the truck.
(I've become so spoiled using lifts that my saying is "If I can't lift it, I don't work on it!)
B. W. is offline   Reply With Quote
Old 10-19-2017, 06:41 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Third member... are you installing a 9" or a D60?
If I have the rear end out of the truck, I assemble it on a set of sturdy saw horses and then install the whole thing under the rig at once.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
