10-20-2017, 09:36 PM | #1 |
Roof Marker Lights
My roof lights are not working, are they suppose to come on with the parking lights and the rest of the lights? Possible causes, fuse, headlight switch, etc.
Thank you
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
10-20-2017, 09:42 PM | #2 |
Re: Roof Marker Lights
I believe that's a yes and a yes (with parking only and with headlights too) - but hopefully someone can confirm the "with parking lights" part - I'm not 100% certain on that one. If they didn't, I'd wire them to do so anyway . I'd check fuses, but my first guess would be the switch. Were they working before?
10-20-2017, 09:49 PM | #3 |
Never checked the function of the lights before I tore it down. Wiring is all there and I have new lenses and gaskets. Thanks
10-20-2017, 10:38 PM | #4 |
The Older Generation
My '72 C30 cab lights work with the park lights and the headlights. LockDoc
10-21-2017, 08:14 AM | #5 |
My 68 has a brown wire that plugs into the fuse box.
10-21-2017, 09:13 AM | #6 |
With parking and headlights is correct. Must be a cut in the wire if the brown wire is connected.
10-21-2017, 09:34 AM | #7 |
Awesome, thanks for the replies and I'll let you know what I find.
10-21-2017, 09:45 AM | #8 |
The brown wire will run down the left A post from the roof and come out near the bottom of the dash.
10-21-2017, 01:46 PM | #9 |
I was just going to ask where the wiring was, thanks
10-21-2017, 03:09 PM | #10 |
This is from the Factory Assembly Manual. The manual is available on CD and has a search feature. Good reference material..... LockDoc
10-21-2017, 06:01 PM | #11 |
10-21-2017, 08:07 PM | #12 | |
Works good. You do have to think about the search words you use. I typed in Clearance lights, no go, typed in just lights and some stuff came up but not this, then typed in lamp and bingo! (see #1 in the illustration).... LockDoc
10-24-2017, 02:54 PM | #13 |
The cables from my roof light goes back on the roof and down inside the cab where the gas lock is located. Then it goes on the floor to the switch. I need to draw new harness, but the old one is stuck. Is it possible to lineup new cables like the factory assembly manual? Don't I need to drill some holes then? What's your suggestion?
10-25-2017, 06:18 PM | #14 |
Update, problem solved! While assembling the dash I apparently knocked the ground wire and clip off the lower dash. Thank you for the replies. Thanks for the manual pic lockdoc, I had the manual on the seat next to me but didn't think to use it.
10-25-2017, 07:50 PM | #15 |
Pic!
10-25-2017, 10:07 PM | #16 | |
No problem, Glad you got it figured out. I wouldn't have thought about that ground clip affecting the cab lights. Good find...... LockDoc
