Old 10-21-2017, 12:40 PM   #1
Coley
Coley's Avatar
How to change out the engine on an RV/Motorhome?
Anyone know what it takes or 'how to do it' to change out/replace the engine on a 'C' series motorhome/RV?
That is the kind of RV that has the standard (GM) 'van' front end only and then a big full body camper shell attached and integrated into it.
Now, I know that if it was 'just' a regular van you would do it from/through the sliding side door. However an RV does not necessarily have that size of door in that location....plus its interior rv stuff might be in the way?
Is this someone done through the front end, thus removing the rad support, bumpers, hood, etc...hmmm? or remove the passenger seat and go through the passenger door? .....or?
...just curious if anyone has any history with this, witnessed it or actually done it.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 10-21-2017, 01:57 PM   #2
100%Chevy
Re: How to change out the engine on an RV/Motorhome?
I own a 86,G-30 rv.
It looks like it would be easier to go thru the passenger door opening.
Remove the engine cover and seat.Then the door.
After that,just un-hook the engine stuff and reach in with the engine lift.(leave the trans in there)
I also have a huge motorhome that I bought for the big block Chevy engine.
I had to cut out the whole front grill area,thinking I''ll stick the engine puller straight in and grab it.Almost worked!Except there wasn't enough room left to lift it without hitting the dash.
So,thru the door on both next time!
Mike.
100%Chevy is offline   Reply With Quote
Old 10-21-2017, 02:36 PM   #3
truckster
truckster's Avatar
The last one I did I unbolted the front crossmember and dropped in out the bottom. It's a pain, but it seemed easier than the other alternatives. Of course, that's been years ago, so my memory's a little foggy.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is online now   Reply With Quote
Old 10-21-2017, 03:10 PM   #4
bill3rail
bill3rail's Avatar
I have done vans through the front end. Just remove hood down and get a tight lifting chain with a lowboy hoist so it goes straight in and lifts it.
From what I can recall, it was a *****, but I completed the job.
It is those big ass class A's which are insane!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 10-21-2017, 04:16 PM   #5
Bigdav160
Bigdav160's Avatar
Van engines should come out the front by removing the hood, grill, core support, radiator, a/c condenser (if equipped)
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-21-2017, 05:35 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
What Bigdav160 said ^^^
Last time I removed an engine in a van, we drove the van onto ramps at all 4 tires and then removed all of the above from the front end, and removed the engine through the front with a regular hoist. Driving it up onto ramps helped raise the rig high enough to use a standard sized hoist.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-21-2017, 05:42 PM   #7
Hutch
Hutch's Avatar
It should come out the passenger door
The hoist will need the extensions for the feet and hoist as it will need the extra reach
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 10-21-2017, 05:48 PM   #8
randy500
I’ve done dozens of engine changes in chevy vans to include Astro vans too.
The engine is not removed from the passenger door nor the sliding door. That would be impossible to do.
The upper portion of the core support is removable, remove that along with the grill and readiator, you may have to remove the bumper to get the grill out.
The engine will almost always come out complete with all accessories and exhaust manifolds.
Your engine hoist needs to be as close to the carb mount surface as possible to get enough lift, use a carb lift plate. I slotted the boom of my hoist to slide into the carb lift plate for max lift.
Remove the engine mount through bolts then remove the engine frame stand bolts at the cradle.
When you slightly lift the engine the frame stands will fall away creating additional clearance to slide the engine out.
Goes back in easy the same way, just get the engine in place, bolt to trans then install the frame stands.
If you don’t remove the frame stands there is usually not enough room to lift the engine over the stands because the hoist hits the cowl preventing enough lift.
randy500 is offline   Reply With Quote
Old 10-21-2017, 05:52 PM   #9
randy500
adjust the height of the van body using jack stands so the engine hoist boom is approx. level when attached to the engine for max lift and clearance.
Old 10-22-2017, 03:42 PM   #10
Coley
Coley's Avatar
Ok......so probably out the front of the Van...with a lot of disassembly....and 'maybe' out the passenger side door.
Anyone have anything more on either of these two options, history, why or why not?
Also, time wise how would a project of this scope compare to a regular 'engine' swap?.....
Coley
2000 Dodge Ram 1500
Old 10-22-2017, 03:56 PM   #11
randy500
Time wise I can pull a van engine as quick as a truck engine. Honestly it’s easier than you would think. Grill and bumper should come right off, about as time consuming as removing and storing a truck hood. Then the remainder is just like a truck. Sometimes I will remove the seat but usually not.
Also on all engine removals, any Chevrolet, unhook the engine wiring from the firewall and then unfasten harnesss back to engine and lay harness on engine, saves much time and prevents wiring hang ups.
If somehow you make the bad decision to not remove the engine frame stands then you will have to remove the starter and oil filter to clear the stands.
I will post a picture of the engine lift plate attached to the hoist so you can see how to get the most clearance.
Old 10-22-2017, 04:14 PM   #12
randy500
Pic of hoist attached to carb lift plate, using the front hole only unbalances the engine a small amount. This arrangement give you max lift clearance since the interference is the hoist boom contacting the cowl under the windshield wipers.
Old 10-22-2017, 04:15 PM   #13
randy500
Slotted hoist boom.
Old 10-22-2017, 11:59 PM   #14
Ozzy2013
Ozzy2013's Avatar
Cool thanks for the info!If i ever do one now i know .
Ozzy2013 is offline   Reply With Quote
Old 10-23-2017, 11:31 AM   #15
kwmech
I've done it both ways. Coming out the pass door, the intake and cylinder heads need to be removed in vehicle to prevent scraping the door post and door panel. Out the front (even though you have to remove a bit of sheet metal and disconnect the AC) is much easier than disassembling the engine on your knees.
Old 10-23-2017, 12:52 PM   #16
Coley
Coley's Avatar
....very good info guys....and it sounds like coming straight out the front would be the way to go.
Many Thanks!
Coley
2000 Dodge Ram 1500
Old 10-24-2017, 06:18 PM   #17
toms68cst
toms68cst's Avatar
I immediately thought of this old thread when I saw the words "Motorhome" and "engine removal."
http://67-72chevytrucks.com/vboard/s...ight=motorhome
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is online now   Reply With Quote
Old 10-25-2017, 12:13 AM   #18
Hutch
Hutch's Avatar
That is the first thought I had after reading the post title
A great adventure from the past
Only Tx Firefighter would use a Mountain Dew to put out a motorhome fire
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
