Rams horn manifolds-aftermarket
Has any used the aftermarket rams horn manifolds on our trucks?I was looking at the ones from Jegs and Summitt,they are center dump and I was wondering about crossmember clearance.
Thanks. |
Re: Rams horn manifolds-aftermarket
Straight dumps on a 2wd creates a really tight turn for the head pipe. Some on this forum have done it though.
Active Member
![]() Join Date: Jun 2016
I've been looking at these:
https://www.ebay.com/itm/130926210500 But I'm going to do headers. It would be nice if we could do center dumps. Speedway makes a line of center dump style headers.
David Larsen 1970 Chevrolet C-10 |
![]() ![]() Join Date: Sep 2008
I bought a set of the center dump with 2 1/2" outlet by Dorman for my 4x4 but haven't installed them yet.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
I deliberated this choice for a long time...header vs manifolds...straight dump vs angled dump. Finally, I just decided to try it and ordered Dorman 2.5" straight dumps on my 1972 GMC 2wd LWB 350/350. My small town exhaust guy did a beautiful job and I couldn't be happier. No noticeable change in performance compared to the long tubes that were on it. No leaks and no pipe ring tone to the exhaust. My reading seemed to indicate it all depends on the ability of the installer. I was very fortunate.
I'm using the chrome ones from summit on my 72 K10. The center dump works great on the 4wd.
![]() Join Date: Jun 2004
I bought the center dump ones from Summit and my local shop said they won't work on my 2 WD. (I'll sell 'em cheap!) I went with aftermarket ones that the dump curves back. The only difference is appearance.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
How CHEAP ?
![]() Join Date: Jul 2015
X2 Except my muffler shop is me, and I fabbed together my exhaust, it works great! Check this place out, if you know how to weld an exhaust system on one of our trucks is very easy to weld up. http://www.gbemandrel.com/ Last edited by toolboxchev; 10-23-2017 at 02:03 PM. |
![]() Join Date: Nov 2004
This is actually good timing for me as I'm pretty sure my original DS manifold has developed a crack.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Wow, so apparently those manifolds in the ebay ad match the dorman PN's on summits site, for LESS THAN HALF of summits price??? Can anyone confirm you actually get the dorman manifolds in their pic and not a knock off? The auction isn't clear...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-23-2017 at 03:12 PM. |
I used stock center dump rams horn manifolds on my 2WD.
I think outlet pipe is smaller than exhaust pipe. It increases in size after it turns to the rear. It is tight, but nothing hits, and you can get to the bolts with a little work. Last edited by Zeroman; 10-23-2017 at 04:32 PM. |
#13 |
Here are some close ups....
#14 |
I have stock ram horns. Dumb question but why do people like the ram horn setup??? I was going to go the header route but if they flow good then I will keep. Whats the thought here???
Thank you |
#15 |
1. They flow well
2. They allow the exhaust to tuck up tight 3. They are the correct manifold (if that matters) 4. None of the issues that some headers have 5. factory brackets bolt up 6. Fewer interference problems on custom applications |
#16 |
I'm pretty sure my DS manifold has cracked somewhere. I bought the ebay set because they're so cheap ($82) and appear to be the same dorman part that summit sells for +/-$90each.
I will let everyone know how they fit. I believe the ones on ebay are the factory style, they're center dump, but angled back. That's what is on my truck now, and I'm pretty sure I got them off of an original 67 with a 327 back in the day. I even took the correct spark plug heat shields off of it... I think... been a LOOONG time.
#17 |
![]() Join Date: Mar 2011
I bought the aftermarket , large diameter style to use instead of headers. I'm running a Muncie 4 speed and had interference issues on the left bank. I had to go back to the smaller factory ram horns. Id sell mine also.
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
#18 |
X2 and add that some people thought I was running headers from the sound the ram horns make.
Michael ![]() |
#19 |
Thanks for all the input.
#20 |
![]() Join Date: Nov 2012
My 68 Stepside has an aftermarket ramshorn by Dorman on the passenger side. I do not remember any issues when it was installed for the dual exhaust.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
#21 |
![]() Join Date: Nov 2006
The 2 1/2 inch outlet is a corvette manifold. I have several sets. Good heavy castings. I polished 1 set and they turned out nice. I use tight radius mandrel bends comming out of the manifolds then muffler shop after that.
I BELIEVE IN JOHN 3:16 |
#22 |
I had to try to work on my house and truck this weekend and the house won out (replaced a couple exterior doors) but I did manage to get my old manifolds off and one side back on. The fit was pretty dang good.
And yes, the ebay ones appear to be the dorman ones, but literally half the price of anyone else. If you're thinking about buying them (they're the factory style ones with angle back) I would pick up a set. They do need a little grinder work to look a little better and they do have 4 stupid looking plugs (visible in pics) but otherwise look decent.
#23 |
the vette manifolds need the generator mount cut off, buy direct from dorman. last set I bought was about 170.00 there for the 327/365 hp engine
#24 |
![]() Join Date: Jan 2001
And you won't deal with the annoying drone coming from the firewall area.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#25 |
This is the same set I used, they work great but the exhaust pipes will be custom and the right side is very tight. I moved the motor a little to add clearance and made the pipes by making wire templates and had the 2.5" pipes bent then I cut and welded them to fit from there. It was a job but I wanted the stock look with the performance improvement.
