Old 10-23-2017, 07:13 PM   #1
0bad0boy7
1966 C10 Auto to Standard Transmission +Engine Swap
Hey Members,
I am hoping to get some wisdom about my plans for a 1966 C10 that I hope to make a dependable daily driver. Currently it has a bad 700r4 transmission and a 4.3 V6 that was taken out of who knows what (I should take photos of the homemade motor mounts it is setting in. WTF is all I can say about that).
My wife says that I can spend 10K max to make it a dependable daily driver.
So my thoughts are to buy a turnkey crate motor (about 5K from blueprint, jasper, or someone else w/ warranty) and a standard transmission (hopefully 2K or less with clutch and bell housing). I am not sure which engine/transmission would make for an easy instal that I can accomplish over the Thanksgiving Break.
I am sure that I will also need foot pedal assembly for clutch pedal.
Has anyone done an auto to standard transmission swap like this? If so what were the troubles you ran into, and what advice would you give?
Thanks in advanced for any help!!!
Mark
P.S. I saw Jocko has a nice post on swapping to a T-5 but it sounded like that was manual to manual transmission swap.
0bad0boy7 is offline   Reply With Quote
Old 10-23-2017, 08:12 PM   #2
DPowers
DPowers's Avatar
Re: 1966 C10 Auto to Standard Transmission +Engine Swap
Was your truck originally a manual or auto? Summit usually has some good prices on their crate motors. May want to take a look at them. Also a supporting membership will allow you to post want to buy for the little things that you are going to need. Motor mounts, pedal assembly etc. Also pics would be helpful to what you are starting off with.
DPowers is offline   Reply With Quote
Old 10-23-2017, 08:41 PM   #3
PGSigns
PGSigns's Avatar
Welcome to the board. Pics will be a big help in getting you going. I second the supporting member.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-23-2017, 09:24 PM   #4
0bad0boy7
Powers & PGSigns: Thanks for the reply! I am not sure what the truck was originally since the steering column, engine, and transmission are all transplants.
The motor is a 4.3L V6, which I understand to be similar to the 350 V8 but missing the last two cylinders.
Old 10-24-2017, 12:19 AM   #5
Lil Loafer
Is the v6 a vortec? If so I could consider keeping it if you just want a daily driver. I don't know if you would be able to shred the tires like you could with a sbc, but the 4.3 vortec v6 was a good motor. A friend of mine had one in his truck, and he kept up just fine with the boys with 454s.
Lil Loafer is offline   Reply With Quote
Old 10-24-2017, 01:48 AM   #6
'63GENIII
'63GENIII's Avatar
I went from a TH400 to an NV4500 in mine. Hydro clutch master from Willwood, slave from Dorman. Not apples to apples but kinda. Had to get the pedal assembly which went in fairly easy. Clutch rod to master alignment still bugs me but I drive it all the time nonetheless. Using the factory V8 motor mounts for the big block. Wish I could have moved it forward an inch. Stars have to be aligned, tarot card in order and my wife shaking animal bones in a jar just right for the passenger side valve cover to come off . Other than that... its easy.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-24-2017, 07:38 AM   #7
0bad0boy7
Lil Loafer & 63GENIII: I think it is a vortec 4.3... The motor is crammed so far back into the transmission tunnel that I can not see the casting number on the block or heads. I am going to pull the engine/transmission out this weekend and see what those numbers are. I could save money big time if I could have this block/heads rebuild. Then I would only need to find a good standard 5 speed gear box, bell housing, clutch, foot pedal assembly.
Can you move your engine/transmission forward by moving the mounts and a longer drive shaft? I don't know how many problems I have gotten in thinking that "It should be easy as that" and then realized half way in " I didn't think of X, Y, and Z."
Old 10-24-2017, 11:25 AM   #8
Short 3/4
Nice truck. Don't forget to budget in time and money for wiring. If you are looking for a reliable driver you don't want a spliced/hacked mess. The good news is quality harnesses are available for both stock and custom applications, but I was very surprised how fast the cost added up.
Good luck, Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 10-24-2017, 01:33 PM   #9
jchav62
1962 C-10
jchav62's Avatar
If I remember correctly... the 4.3 Vortecs will have the word Vortec on the valve covers. Do I see A/C there too? Seems to be a nice little pickup there.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-24-2017, 06:16 PM   #10
0bad0boy7
Joseph, the truck you drew at the bottom of your signature page is awesome!
Old 10-24-2017, 07:27 PM   #11
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Ya know, the 4.3 is still put in base trucks today but they have fuel injection and have nice power. Just a thought.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-24-2017, 07:51 PM   #12
0bad0boy7
I have been think about keeping the V6 the more I look at what is already in the truck. Maybe just pull the transmission out and have it rebuilt and get back on the road.
Old 10-24-2017, 08:19 PM   #13
AcampoDave
AcampoDave's Avatar
When I swapped from auto to stick, I found a rusty, crusty parts truck that had all the manual tranny stuff intact. That way I had all I needed plus a few good "other" parts. I even sold off some of it when I got done.
AcampoDave is offline   Reply With Quote
Old 10-24-2017, 08:27 PM   #14
0bad0boy7
Was the donor parts truck a 60-66, or did you have another year and model that worked for you?
Old 10-24-2017, 08:27 PM   #15
64 Stepside
64 Stepside's Avatar
Not a bad way to go. That's what I would do, unless you do those kind of swaps all the time they can end up turning into a long term project with a lot of money poured in. The domino effect takes hold, ask me how I know
64 Stepside is offline   Reply With Quote
Old 10-24-2017, 08:33 PM   #16
0bad0boy7
Not what I want to hear, but sounds like what I need to hear!
I don't do them all the time. I am a school teacher (second grade for now, but hopefully soon wood shop and welding).
It is looking more and more like I should have the 700R4 transmission rebuilt and put some real motor mounts under the 4.3L engine. Focus on the suspension and breaks next, rebuild the motor last, and cosmetic stuff very last.
P.S. What happened? What did you domino with?
Old 10-24-2017, 10:12 PM   #17
AcampoDave
AcampoDave's Avatar
It was a 63-66 donor. I actually just swapped the whole darn frame 'cuz the donor was a shortbed and mine was a longbed '66 w/factory automatic. (It's my avatar truck) I do get some confused looks when I tell people that I swapped from auto to stick, but I just like the shifting, the sound, and the reliability. Even my 2wd Tacoma work truck is a stick and when I went looking for a new one with a manual trans, the Toyota dealer laughed and said it was "like finding a unicorn". I ended up with a new motor and clutch instead. I guess gear bangers are a vanishing breed.
Old 10-24-2017, 11:55 PM   #18
Captainfab
60-66 Nut
If you do end up having the 700R4 rebuilt, make sure that the TV cable is connected correctly and that the trans pressures are correct. If you do not, that new trans will not last long.
Old 10-25-2017, 06:17 PM   #19
nail pounder
nail pounder's Avatar
X2. Unless it needs a motor I'd leave it, spend the money on other things.
nail pounder is offline   Reply With Quote
1966 c10, 1966 chevy c10, manual swap, transmission swap
