10-24-2017, 01:19 PM | #1 |
Eaton or Auburn?
I want to get a limited slip carrier, I have 3.73 gears already so I only am going to swap the carrier itself.
So I've come down to these 2 for my choices but beyond what they can tell me in specs I don't know if one is better than the other. I'm sure you guys have seen both in action... What should I get? MOD
Chad '71 GMC 2500 Custom Ol Blue '72 Custom Deluxe Highlander Stuffed Olive '73 Trans Am '13 Silverado 2500 Duramax Storm Trooper |
10-24-2017, 01:28 PM | #2 |
Re: Eaton or Auburn?
Unless they have changed, the Auburn is not re-buildable so I'd go Eaton.
10-24-2017, 01:40 PM | #3 |
Went with the Eaton Detroit Truetrack performance posi put in a Nodular Iron housing. Very adaptable for all road conditions and exceptionally rugged.
http://www.eaton.com/Eaton/ProductsS...trac/index.htm
1972 C10 SWB, 1970 Corvette, 2017 Grand Sport Last edited by skytop; 10-27-2017 at 11:19 AM. |
10-24-2017, 06:27 PM | #4 |
I went w/ Eaton Truetrac also.
JMC1965 1967 C20 LWB
10-24-2017, 06:42 PM | #5 |
They haven't changed. You can't rebuild an Auburn posi.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-24-2017, 08:39 PM | #6 |
Eaton. I own a couple of Auburns for Dana 44's. I got them on a clearance deal for $180 each. For my off-road intent they will last forever and at that price nothing could touch it.
But for the raod, Eaton all the way. Wouldn't even consider the Auburn.
10-24-2017, 08:43 PM | #7 |
Recently installed an Eaton Truetrac. Have not finished my build yet to see how it works but looking forward to it.
10-24-2017, 09:00 PM | #8 |
You can't go wrong with either. Both are top shelf quality units that are time tested and proven tough. From way back I'm a Detroit Locker rear/TruTrac front 4wd guy. Still best bang for buck in 4wds. But I have run a Auburn in a couple 12-bolts, both 2wd and 4wd and they held up to it all, almost all on the road.
10-24-2017, 09:41 PM | #9 |
I just installed an Eaton Limited Slip this summer and it is great. On the street you wouldn't even know you have a locker. It is rebuildable and you can put in different springs to make it more aggressive, if needed.
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
10-25-2017, 03:03 AM | #10 |
Tru-trac, will always perform in the same manner. All gear drive, no clutches to wear out. When you buy you'll have to specify it is for the front. They are somewhat directional.
10-25-2017, 10:58 AM | #11 |
Thanks for the advice guys, Stuffed Olive will be getting some form of Eaton in the near future.
I feel bad for that left rear tire it's missing out on all the fun!! MOD
10-25-2017, 05:09 PM | #12 |
Is anyone using this?
Powertrax Lock-Right Lockers 1910-LR https://www.summitracing.com/parts/p...0-lr/overview/ I've been using the car version in my 518HP 67 Cutlass with a 468 BBC for about 15 years without any issues. Seems to be cheaper than the Eaton.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI Last edited by Rufas; 10-25-2017 at 05:54 PM. |
10-25-2017, 05:31 PM | #13 |
Active Member
I had been looking at getting this set on ebay, comes with a Yukon Duragrip posi, but unspecified brand ring & gear. It's just really cheap, about $200 less than buying the install kit, ring & gear, and the eaton truetrac.
David Larsen 1970 Chevrolet C-10 |
10-25-2017, 05:33 PM | #14 |
I did a lot of research and the vast majority I found said to go with and were happy with Eaton. So I bought one, but it's still in the box... I have to rebuild the rear its going in first...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
10-25-2017, 08:44 PM | #15 |
Eaton for me i just installed 1 in my 70 c10
I BELIEVE IN JOHN 3:16 |
10-25-2017, 08:50 PM | #16 |
I wouldn't have any issue running the Yukon Duragrip. I would think it came with Yukon gears as well which I also have used quite a bit with no issues.
