10-25-2017, 07:50 PM | #1 |
Trailing Arms?
’72 C10 full-size bed. Trailing arms are separating. Weld them up? Weld on top & bottom plates? Get new? (if “get new” - where?) Thanks
10-25-2017, 08:33 PM | #2 |
Re: Trailing Arms?
If it were me and my OEM were compromised I don't think just welding them up would make me feel all that great. I would replace. I think I saw that ECE had some new arms available, and I have found all their stuff to be excellent.
10-25-2017, 10:02 PM | #3 |
The Older Generation
Re: Trailing Arms?
I separate them, clean them up, and stitch weld them back together.... LockDoc
10-26-2017, 08:01 AM | #4 |
Re: Trailing Arms?
I bought the ones from early classic enterprises that are solid and way heaver that the stock , just get some poly urethane grease for the bushings before installing them
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
10-26-2017, 02:31 PM | #5 |
Re: Trailing Arms?
i bought a pair of 3/4 ton ones and welded them up but there was nothing wrong with them, installed new bushings and have new u bolts, just hav'nt put them on yet, thinking about selling them, i'll post pics of the welds if anybody is interested in seeing them.
they also have been powder coated
"Send in the clowns the goats are loose" |
10-30-2017, 10:22 PM | #6 |
Re: Trailing Arms?
Thanks for the replies. I bought new - because I have money I haven’t even borrowed yet. What’s the secret(s) for getting the front bolts out - and how do I remove the e-brake cables from the clips? Thanks
10-31-2017, 09:08 AM | #7 | |
Re: Trailing Arms?
And the clips I just used vice grips and pulled them
