Old 10-28-2017, 03:24 PM   #1
ABQ-C10
ABQ-C10's Avatar
Rack and pinion issue!
I just installed the Ford rack and pinion in my ‘67 with dropmember. I did the psi reduction kit in my PS pump as well. With that being said, it feels like I have manual steering! I pulled the return line and it’s getting a nice steady flow back to the pump. Any help on this? Any ideas? I have had it jacked up and slowly going back and forth with the wheel, but to no avail.
1967 C-10 Stepside - The "Patina Machina" build here! *SOLD*
1984 Chevy C30 crew cab dually - 454/4L80E, Airbags, 4-link/Watts link, 22" Alcoa wheels
Patina Customs
ABQ-C10 is offline   Reply With Quote
Old 10-28-2017, 03:54 PM   #2
ABQ-C10
ABQ-C10's Avatar
Re: Rack and pinion issue!
Has a 5.3 in it BTW. Put in 4 shims to bring pressure down to 800psi, but there is NO power assist at all.
Patina Customs
Old 10-28-2017, 07:22 PM   #3
B. W.
B. W.'s Avatar
It sounds like you need to bump your pressure up. Remove 1 or 2 shims & try it.
B. W. is offline   Reply With Quote
Old 10-30-2017, 10:18 AM   #4
ABQ-C10
ABQ-C10's Avatar
Self-inflicted issue. Sometimes you can be your own worst enemy. All fixed and works like it should!
Patina Customs
