Old 10-29-2017, 08:46 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Steering box and rag joint questions
This came off my 71 2WD C-10. Current plan is to send it out to have it rebuilt. A couple questions per the captions in the images below, and input appreciated. Thank you.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 10-29-2017, 09:35 PM   #2
71CHEVYSHORTBED402
Re: Steering box and rag joint questions
Checking some of my old notes, I think the shaft (#2) is called a worm shaft.
Tony
Old 10-29-2017, 10:23 PM   #3
BCOWANWHEELS
Get a oriellys rebuilt box, its lifetime guarantee. Get new rag joint assy from autozone number 200 or 201 cant remember
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-29-2017, 10:41 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
#2 is the splined end of the worm shaft
#3 is the ground wire for your steering shaft
#4 is a keeper
#5 is the housing top cover with the lash adjusting stud and lock nut
LockDoc
Leon
Old 10-29-2017, 11:18 PM   #5
71CHEVYSHORTBED402
#4 is a keeper
LockDoc
BINGO........ Thanks again Doc.
Go figure, the steering ground at the very bottom. I wouldn't have guessed, somehow. ...I suppose it's grounded where it mounts to the cab as well.
Happy to say my "not sure" box only had 4-5 small pieces. Minus one, appreciate it.
Tony
Old 10-30-2017, 12:14 AM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Ecklers also carriers replacement rag joints. I had my original steering box rebuilt by Red Head steering in WA. Does the date code on your box suggest its original?
Old 10-30-2017, 11:03 AM   #7
71CHEVYSHORTBED402
In addition to the stamps mentioned in the second image, it's stamped with a "4". There's another stamp with maybe 3-4 characters. Can't make it out.
The top is stamped "119 71". Might mean 1/19/1971.
The box is original alright. I took the truck to a mechanic before I bought it in 1989. He said the only thing wrong was the steering box leaked and needed a replacement. I never replaced it.
Thanks for the lead. I don't see me rebuilding the rag joint. Honestly, the rubber on the old one looks great, but I figure new is called for. What the heck at this point. Brand new truck, someday, yikes.
BTW, Red Head steering finish it for you? Out of a rattle can or gun? She's packed away, mostly clean.
Tony
