11-09-2017, 09:34 PM | #1 |
Scenario: Which frame to use?
If you were to build '67 swb and had 2 frames to chose from, 1 with rear coils and the other with leafs, which would you use and why?
11-09-2017, 09:47 PM | #2 |
Re: Scenario: Which frame to use?
Coil ,Easier to fine tune a drop and if trailing arms are still good enough for Nascar at 200 mph ...Well , Their still good enough for me at 70 mph.
. “Our rear suspension has two trailing arm. We call them truck arms because it’s much like out of a mid-60s Chevrolet truck" https://www.motorsport.com/nascar-cu...ension-902294/ Last edited by Grumpy old man; 11-09-2017 at 09:54 PM. |
11-09-2017, 09:51 PM | #3 |
I guess it all depends on what You will use the truck for and type of build! For Me I would go with coil springs and trailing arm for 2 wheel drive and leaf springs For 4x4. You going for a work truck or Hot Rod type?
11-09-2017, 09:54 PM | #4 |
Hot rod. Low 2wd.
11-09-2017, 10:10 PM | #5 |
11-09-2017, 11:41 PM | #6 |
If you are going to haul anything that is payload related...then springs are by far a better choice...much more stable and capable.
However if it a simply a light duty run around truck....then the coils. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
11-09-2017, 11:57 PM | #7 |
I got leafs simply cause it was different
11-10-2017, 01:01 AM | #8 |
My truck has springs.....I rather wish it had leafs (leaves? ) so I could carry more of a load.
11-10-2017, 05:55 PM | #9 |
a couple of you made comment about leaf spring hauling more of a load then coil, I would rather have coils for a load. back in the mid 80's my brother-in-law ask me to get him a yard of sand and gravel to pour some concrete with. he had a small import truck, I was young and dumb at the time and jumped in my 68 LWB C10 and ran to town to get it. the fellow dumper a bucket of sand in my truck and it set it down good bit. he took off and returned with a scoop of gravel and dumped it in my truck. I almost $#!+ he jumped off the tractor and I ask what does that weigh and he said about 3000 lbs. I wish he would have told me first but I looked under the truck to see what it looked like and my bump stops still had about a 1/4" of clearance. drove it home at about 50MPH 7 miles and unloaded it as I was afraid it would damage something. all I am saying is I wouldn't try it with leaf springs. and I wouldn't do it again with coils.
11-10-2017, 08:18 PM | #10 | |
