need help with lowering my truck
I have a 67 lwb c 10 pick up. Being on a tight budget, I want to lower the front of my truck about 3 inches without having to replace too many things. Also, I would like to lower the back of the truck about 4 inches. Can I do this without having to c notch it?
Both the front and rear have coil springs. My goal is to have the front lower than the rear but at drive height. Later i will install disc brakes on front and have to replace wheels and tires but for now I want to change the stance. Any help would be appreciated. Thank you.
"Arrive, Raise Hell, Create Confusion, Leave". |
![]() Join Date: Jul 2017
Re: need help with lowering my truck
I have a 67 C20...lowered about like you are asking. GMC Pauls drop springs in back and a shock relocation kit. cut springs in the front to lower...but you would probably do drop spindles instead.
JMC1965 1967 C20 LWB
CPP has a 3/4 drop spring kit that’s fairly cheap and easy. Can’t do drop spindles on the drums.
![]() Join Date: Mar 2014
I ran a 5 inch drop in the rear with no frame mods. I was just about on the bump stops with that but you should be fine. Youll want to do the shock relocators in the rear.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
