Old 11-10-2017, 03:30 PM   #1
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Help! Fittings for Wilwood Proportioning Valve
I'm trying to help a friend install a Wilwood master cylinder and proportioning valve in his '67. The truck has front discs from a '71 with the 5 lug swapped drums in the rear. We are attempting to attach the original 1/4" rear line to the rear port on the proportioning valve. I'm hoping someone has already done this and can help locating an adapter fitting. What I need is a 3/8"-18 male inverted flare to 7/16" female inverted flare. Any help would be greatly appreciated.
This fitting supplied with the M/C has the correct female side but the wrong male side, not inverted flare.
Side view of the fitting with the wrong male side.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 11-10-2017, 04:53 PM   #2
RodnRudy
RodnRudy's Avatar
Re: Help! Fittings for Wilwood Proportioning Valve
You should be able to find that adapter at Auto Zone, O'reillys or NAPA. It will be brass.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 11-10-2017, 05:52 PM   #3
C10_ustacould
I found it, Dorman 785-434 in case anyone else needs it. The trick was, the existing line has a larger tube nut to fit the stock proportioning valve, 9/16-18. I couldn't find a fitting with that configuration. Then I realized I needed to make a new line to mate with the existing line due to the positioning of the m/c which will allow me to use 7/16-24 IFF to 3/8-24 IFM fitting. I'll post pics when it's done.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
