![]() Join Date: Oct 2011
Odd Brake Issue: pedal? system?..... input?
Ok...I have a very odd brake issue that I first started to notice last year.
First, some basic correct information: -The truck is '72, 2wd, 1/2 ton with power brakes (discs on front)...all original. -I have NO loss of brake fluid in the system...reservoir(s) are full. -The brake pads and shoes are in good condition (+50% or more for sure) Now: -When I push the brake pedal down it hits a stopping point (midway?)....for about 5-10 seconds...then if pressure is continued (not lifted) it heads for the floor and the truck starts to creep. Now, if I lift my foot and reapply pressure I get the pedal and the brakes back. So...if the system was using fluid (losing it)...I might think I had air in the system, but there is no loss of fluid. As well, the brakes are extremely 'grabby' when the truck is first started and moved...then they settle down within a minute or two. After that I drive the truck all over the place, but I am aware that when I am at a light, I have to re-apply the brake pedal at least once to keep from creeping after initially stopping. If I 'jam' the brakes while driving, etc.....they definitely grab. so..... Does this sound like the proportioning valve is working properly? Is there a good way to analyze and check this?...a few intelligent, proven tests or? Many Thanks! Coley ![]()
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Re: Odd Brake Issue: pedal? system?..... input?
Most likely master cylinder.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
...any chance of being more specific?
I am trying to solve what exactly is going on here....rather than just starting to replace parts until the issue goes away.....noting that is often the way most 'repair centers' (so called) go about fixing things, lol. Many Thanks Coley ![]()
Who Changed This?
![]() Join Date: Jan 2013
That is a classic symptom of a bypassing master cylinder. The key is that no fluid is lost. Replace it! I wish they were all this easy to diagnose.
#5 | |
...is the bypass within the master cylinder?....or is it the proportioning valve? again, interesting stuff...I'm trying to imagine what the cross section of the master cylinder looks like and what is happening here....hmm Many thanks! C
Usually you can see the levels in the MC start rising in one chamber with a bypassing MC.
Have some one hold down the brake pedal and look in the master cylinder reservoirs. But yes. I have seen one proportioning valve act like your symptoms. The "grabby"ness is a possible sign.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
imagine a syringe full of fluid. You push the plunger to pressurize the fluid. And hold it. Now imagine the fluid seeping past the plunger and allowing the pressure to bleed off.
This is what happens inside the master when your foot goes toward the floor under constant pressure. I am not familiar with the prop valve fail condition though. Hth -klb Posted via Mobile Device |
I had this same excact issue , and yes you pray everyday that you hope you dont need to stomp on the brakes .because you are not sure you will stop in time . So I replaced my master thinking it was a bad master it stiffin up the feel a bit but ,I could still push the pedal to the floor . then one day 6 months later one of my calipers locked up ,soI changed the caliper and then I could push the pedal through the halfway mark but it did not go to the floor ,the next day I changed out the the other side caliper and that made everything 100% Nice high pedal no to the floor firm and nice responsive brake system....
Well so far....looks like it could be a variety of things.
Now, as far as braking goes....if I stomp on it...it stops, it will lock up actually if i hit it hard enough. If it didn't stop or was vague....i wouldn't drive it. It is after it stops....that the pedal starts to float down.... Coley
Who Changed This?
Yes, and eventually you will hit the pedal and nothing will happen, in terms of slowing down.
![]() Join Date: Sep 2015
How old is everything else in the system. I agree about changing out the master cylinder. Keep in mind that its very reasonable to replace all the components of the braking system and keep them up to date. New brake hoses, wheel cylinders, calibers, quality brake shoes and pads. Clean everything really good inside the drums.
#13 |
x2, change the master cylinder immediately! easy to change, bench bleed the master cylinder,change it and you don't have to bleed the lines....
#14 |
![]() Join Date: Feb 2009
Didn't know that. Great idea. Not to hijack the thread, but I have to ask........On completely new brake system, you have to bleed the lines no matter what, right?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#15 | |
Posted via Mobile Device Last edited by El Dorado Jim; 11-12-2017 at 01:55 AM. |
#16 |
So if is the master cylinder...is the fluid that is being compressed by the plunger simply 'cycling' over into the secondary brake system and back? ...noting that the fluid must be going somewhere and it isn't compressible.
Any ideas or description as to what is going on within that master cylinder would be great... many thanks! Coley
#17 |
The hydraulic fluid doesn't compress unless it has air in it. The "plunger" is not sealed in the bore which is allowing the fluid to pass by the plunger.
Refer to the syringe explanation earlier in this thread. When you plunger completely fails ( it is partially failed right now ), pushing the brake pedal will not cause anything to happen ( no brake at all ). Hth, -klb
