View Poll Results: Ochre configuration? | |||
First pic. Two-tone Deluxe. Not original but close enough. |
36 | 85.71% |
Second pic. Standard two-tone. Mostly original, just belts added. |
6 | 14.29% |
Voters: 42. You may not vote on this poll |
![]() Join Date: Feb 2009
Taking another shot on paint scheme - Progress
Yeah a repeat about paint & config........ Probably a repeat on a repeat x3.
Painter called today, he's inspired. Thought I lost him. He wants to know what color. I've spent 28 years pondering that, and I'm close ![]() Anyway, this is an original build. The original config. was two tone Ochre and White (Ochre bottom and White cab top). No moldings outside the paint separator. Either way I'm adding moldings, so it won't be quite to the SPID anyway. But I've decided on Ochre. Only question is standard two-4 tone Ochre and White, or two-tone deluxe Ochre and White? Deluxe is the paint separated between moldings (1st image). I'm leaning toward two tone deluxe, and the painter agrees. But still undecided. What do you guys think? On a side, we've decided to paint under the bed with a bed liner with some sheen. Something he recommends. I THINK these were body color from factory (confirmation?), but seems it wouldn't hold up as well. Dude has had my bed for two years. No problem there, I still have a suspension to remove. He's sprayed it with primer. He said he had it to a beautiful shine, and that's a beautiful thing. Pics. pending. Looks like we're prepping under the bed next week, and he wants the whole body. Say when man, can't wait. On a side, the deluxe would look best with the antenna I'm adding. All else on the exterior will be original. It's a fat -ball fixed mast on a high crown bezel. Best of both worlds IMO, with a fat-ball to boot. The original parts on 67-68 Corvettes. All input appreciated. These trucks are nice. At least one belonged to a board member.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-11-2017 at 10:55 PM. |
Re: Taking another shot on paint color - Progress
Make that 2 for Deluxe with the owner on the fence.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
![]() Join Date: Oct 2009
While it's a classic look, deluxe seems to be what every truck has nowadays. But if it's what you like, then it doesn't matter what everyone else is doing.
But since you asked... personally, I'd go: Solid ochre - or Black top over ochre conventional two tone (great "almost" stock looking combo imo) - or White top over ochre conventional two tone |
I really like the deluxe 2 tone, either will look great though.
#5 | |
Definitely on the fence per the OP. Conventional two-tone is more conservative, and I can appreciate less is sometimes more. On a side, I'm pondering this option as well. No upper belts. Another beautiful truck.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-11-2017 at 08:48 PM. |
#6 | |
![]() Join Date: May 2010
That said, I probably prefer the look of the deluxe 2-tone, but..... Jim |
#7 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#8 | |
Paint and body work are probably the most expensive part of a restoration and the most costly to revert to original. A tilt column, gauges with tach, fancy wood beds, AM/FM, and even a crate engine (all where I deviated from original) are a lot less costly to reverse for the purist. BUT, do what YOU want!!! At least you'd be using the original colors. Jim |
#9 | |
As for me, undecided ![]() I should add Jim, it's not going to add up to the SPID regardless. It had big(*(^ camper mirrors and a rear step bumper. I'm running with sport. But I get it, conventional two-tone takes a giant step toward original. It's a tough call. I like em both.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-12-2017 at 12:33 AM. |
Two Tone deluxe is what I would do adds custom look to it I like.
I drove my body shop crazy on paint color I kept getting samples having them paint an old door I had. Finely the owner called me said pick a paint today or pickup your truck. I thought it would be easy to pick but as I started looking at different colors I kept going with different shades and different amounts of metallic. Paint looked different from a sample when they painted the test panel. I also upgraded to the best clear coat they had has 10 year warranty against UV and scratch resistant. The painter said it was so hard within the hour he had to color sand it right away before it fully cured be too hard to sand I know it was a DuPont product. |
I like the white in the middle and on top
70 SWB STEPSIDE 70 BLAZER 09 challenger |
![]() Join Date: Dec 2013
I voted deluxe two tone on your truck, but I am going with all dark olive and no belt trim on my 71 Cheyenne. Ochre is awesome!
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
#13 |
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
Hard choice. But if someone was twisting my arm I'd go deluxe.
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
#14 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Taking another shot on paint scheme - Progress
If not for the upper molding, I'd say standard two-tone. But since you are adding the upper molding, I'd go with two-tone Deluxe.
Of course your opinion is the one that matters, gonna look great either way!
#15 |
Post Whore
![]() Join Date: Feb 2016
With the exception of the all white 70 my dad had the only other 67-72 Chevy/GMCs I remember from back in the day were the deluxe paint combos. I'm sure there were plenty of non deluxe trucks but they didn't stay in my mind over the years. The Deluxe has my vote.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#16 |
I "may" have polled other venues. Deluxe takes it more than 20-1. This website represents more purists, and I get it. I like the conventional two-tone a lot, and to the SPID is even better.
But I can't get deluxe out of my head, so looking forward to it. My other question is, what do you guys think of something more durable (black) than body color under the bed? I think it was body color from factory. Body color would look nicer IMO, and the truck will spend a lot of time in the garage, but I don't know. Tuff call.
#17 |
![]() Join Date: Oct 2011
Well....I have to say, I was very close to 50-50 on this...the solid color with the white roof looks absolutely great as well.
The good news.....you can't lose either way. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#18 |
Exactly. Wouldn't go wrong solid Ochre with upper/lower belts either. A very stout look, especially with a BBC SWB.
