1970 C20 4x4 brake help
Hi folks. I just bought a1970 Chevy C20 4x4 that has drum drum brakes with no power booster. I want to keep the drums but would like a power booster for drum drum. Can I go to the parts store and get the power booster and master cylinder and just bolt on or are there other parts I need, brackets etc.
thanks Paul |
Re: 1970 C20 4x4 brake help
Hello and welcome. I’m no expert but think you will probably need the brackets between booster and firewall. Then also correct linkage between booster and brake pedal. I’ve never added power brakes to front drum setup before but know it’s possible. I have seen trucks setup from factory like that. If you can post pictures of your brake setup now on firewall, that will help the guys on here help you.
Michael ![]() |
I have a '72 C25 but the chassis from a '69 C30 that ran factory drum/drum vacuum brakes. Everything is the same. Just use the whole bracket, booster and MC and use your distribution block in lieu of a prop valve.
I actually left the front drums on mine when I swapped the frame out about 10 years ago because I was warping rotors whenever I pulled heavy trailers. I haven't had that problem since.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
