Old 11-16-2017, 02:02 PM   #1
dagall
LS Fuel Tank Question
I have been reading about the use of a 1989 Blazer fuel tank with in tank fuel pump for EFI utilizing the AC Delco EP381 or Walbro 255 pump. My question is, are these regulated through the Pump & Sender Assembly or do I still need the Corvette regulator/return combo?
1972 Chevy C10
Shortbed/Wood
Starting LS1 GTO Swap
dagall is offline   Reply With Quote
Old 11-16-2017, 02:40 PM   #2
Devil Pup
Devil Pup's Avatar
Re: LS Fuel Tank Question
Im running the 89 blazer tank with in tank pump. . Im running a GM pump but it is basically the same as those u listed. . as far as the regulator goes, it depends on your set up. . If your motor has a fuel rail set up for a return line than it has a regulator already built into the rail. . . If its a return less one than thats where the corvette fuel filter/regulator comes in. This is the best of my knowledge anyway.
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388
Devil Pup is offline   Reply With Quote
Old 11-16-2017, 09:11 PM   #3
dagall
Thanks, I guess I need the Vette regulator/return. I have an 04 GTO LS1 and it is returnless and has a pressure damper on the rail.
1972 Chevy C10
Shortbed/Wood
Old 11-16-2017, 10:51 PM   #4
HotRodfuelhose
Active Member
The corvette regulator makes for a clean install as you only need one line coming up to the engine compartment. Speedway has a good deal on a bundle with some fittings. https://www.speedwaymotors.com/Speed...PSI,41791.html
And check us out in the vendor area if you want the AN line to go with it.
Here is a photo of my saddle tank sending unit setup with the EP381 pump, works great and is a straight plugin.
Hot Rod Fuel hose
http://www.hotrodfuelhose.com
HotRodfuelhose is offline   Reply With Quote
Old 11-20-2017, 11:12 AM   #5
solidaxel
solidaxel's Avatar
If you are handy with a oxy/ace you can silver solder steel AN fittings on to the tank unit.
Look up Hydraulic Hoses in your area they have Good braided Teflon hoses with AN -6 fittings, don't mention if is for fuel!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
