11-19-2017, 09:03 PM | #1 |
Front disc brake kit... Front hoses rubs on shocks.... Help
I recently did a front disc conversion on my 67 gmc. Got it all together but when steering is locked outward on either side the hose will touch the shock. I see no other way to run these hoses. It has a extra rubber sleeve on it so the hose isn't directly rubbing. Is this acceptable? Should I be looking for another way to do this? It won't get caught in the spring. Pictures just look like it's close but it's not. At no other position does the hose come in contact with anything.
11-19-2017, 10:11 PM | #2 |
Re: Front disc brake kit... Front hoses rubs on shocks.... Help
I did some research and I ordered Bendix hose 88466. Seemed to work for quite a few people so I'll try it.
11-19-2017, 10:44 PM | #3 |
That hose looks to be a little too long. It probably would hurt anything to run it but eventually you would have a worn spot where it rubs on turns. I think it would take years to be a issue though.
Posted via Mobile Device |
11-25-2017, 02:40 PM | #4 |
11-25-2017, 04:37 PM | #5 |
I haven't got mine yet. I will get them next week and try them then.
11-25-2017, 04:50 PM | #6 |
Cool, let me know your thoughts.
-Paul |
11-28-2017, 09:42 PM | #7 |
I installed one side tonight. It works but now at full lock it is 1/2" away from the tire. Dang conversions. Thought on this?
11-28-2017, 09:46 PM | #8 |
Moved it around a bit. This is better!
11-29-2017, 03:13 AM | #9 |
Yeah thats a 69 chevelle disc brake hose.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
11-29-2017, 08:04 AM | #10 |
11-29-2017, 08:13 AM | #11 |
I never measured them but I can. I do like the length but I realized last night that my calipers are on the wrong sides with the bleeders pointing down. I will have to swap them to make sure the hose route is still good. Not sure when I'll get to that.
11-29-2017, 11:27 AM | #12 |
Same issue here. This is the stainless steel brake line kit from CPP, trying to figure out the best way to coil the snake:
1970 C-10 "Old Yeller" |
11-29-2017, 12:19 PM | #13 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=738254
