Old 11-20-2017, 09:17 PM   #1
pappy 2
brake line tabs
Does anyone else have the brake line tabs welded to the front on the front cross-member. I am thinking someone had done this for whatever reason. The new 11.5 inch lines I have for replacements are to short since lower the front 4.5 inches. Anyone out there know of a replacement brake line to use. Do not really want to relocate the tabs as everything in now painted and finished
pappy 2 is offline   Reply With Quote
Old 11-20-2017, 09:57 PM   #2
HO455
Post Whore
HO455's Avatar
Re: brake line tabs
I believe you have a 71 or 72 cross member. The factory brake lines run on the front side of the cross member of those years from the factory. Do a search and I am sure you will be rewarded with the part number of a longer hose that works on a lowered truck.
Good luck
RIP Bob Parks.
Old 11-20-2017, 09:57 PM   #3
sduckworth13
sduckworth13's Avatar
Re: brake line tabs
I believe I used 1973-1987 one ton brake hoses. They are about about 3 inches longer.
Scott
sduckworth13 is offline   Reply With Quote
Old 11-20-2017, 10:02 PM   #4
pappy 2
Re: brake line tabs
Thank you both for the quick replies, will check with the parts stores in the morning.
Jack
Old 11-20-2017, 10:07 PM   #5
sduckworth13
Re: brake line tabs
Pappy you can use the 71-72 3/4 ton or 1 ton brake hoses also, they are a inch longer. I liked the 73-87 hoses because they're considerably longer.
Scott
