Diff help
I have a 71 c20 with a eaton ho52 it started a winning noise what can I do to fix it or what diff should I use to replace it
Re: Diff help
Easiest is just replace the "chunk" as the 9" guys call the complete gear/differential setup in the housing if you can find a good used one.
I would look for a Dana 60 if you are looking for a bolt-in swap, but if you can fab then either a Full-Float 14 bolt if you work the truck pretty hard or a semi-float would be great if you just use it and don't abuse it. Either are fairly common with 3.73 or 4.10 gears. If you have 4.57 and want to keep them, the full-float 14 bolts are out there with 4.56 gears.
Re: Diff help
What kind of fab would need to be done for 14 bolt
![]() Join Date: Mar 2003
Re: Diff help
Re: Diff help
Its coil
![]() Join Date: Nov 2006
Re: Diff help
install a modern 14 bolt or dana 70
I BELIEVE IN JOHN 3:16 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Diff help
Is it whining all the time? Or only while accelerating, or.....?
Reason I ask is many years ago, mine started making a slight noise on deceleration only. Turned out to be a slightly pitted pinion pocket bearing. New bearing fixed it and it's been good ever since.
Re: Diff help
All the time
Re: Diff help
to fix it right you need to completely strip it down and go thru it. if you can get the parts. all else is jack legging it.
Re: Diff help
20' Daredevil (Ret)
Re: Diff help
From what I have heard, bearings are common but gearsets are like hen's teeth. Good luck.
Re: Diff help
No use looking for bearings inner pinion bearing housing has a big chunk missing
#13 |
Re: Diff help
Bolt in solution is either a donor center section or Dana 60. IMO, the best solution is a later model housing with shock and mounts replaced. The semi-float 14 bolt is cheap and as strong as the Dana 60. May not have the panache though. The full 14 bolt is almost as cheap and super stout.
