Trans swap, remove bell housing crossmember?
I'm swapping the trans out in my 69 C10 from a np833 to a th400. The np was hooked up to a bell housing crossmember. I am going to use a CPP crossmember on the th400, do I need to remove the old crossmember for it to fit? If not I'd like to leave it for rigidity purposes.
Thanks |
Re: Trans swap, remove bell housing crossmember?
You'll need to take that out, don't worry about strength you have enough
Perfect, thanks.
