11-27-2017, 10:34 PM | #1 |
Where does LMC Cigarette lighter blue wire plug into?
I got it working with the red but the blue connector which it says goes to the fuse panel doesn’t have a spot for a connector like this
1977 SWB (c20 conversion) SBC350 Springfield Oregon Instagram: @nevernotchevy |
11-27-2017, 10:38 PM | #2 |
Re: Where does LMC Cigarette lighter blue wire plug into?
That looks like what goes on the backside of the socket.
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
11-27-2017, 11:45 PM | #3 |
11-28-2017, 01:28 AM | #4 |
That's correct.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
11-28-2017, 07:05 AM | #5 |
Old member
Is this what you have?
The blue wire should go to your lights so that at night when you have lights on it will light up. More than likely you will have to cut the wire and use a crimp connector. I would tie into the heater/AC light bulb.
11-28-2017, 08:06 AM | #6 |
For the light, I believe. There should be a female connector available for it if I remember correctly (no guarantee of that though).
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
11-28-2017, 12:17 PM | #7 |
Msgt USAF Ret
See my post in the electric forum. VV
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
