![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Ignition switch replacement
Finally got the '69 up and running after many years of it sitting around. Comes to find out my ignition switch has intermittent contact problems and is causing issues. Any places out there you could recommend where I can purchase a new switch that is going to be reliable?
Also looking for a headlight switch and a dimmer switch - same intermittent contact issues. Truck sat in a humid environment for a few years and corrosion built in before I moved it out to SE Arizona. Thanks in advance.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
#2 | |
The Older Generation
Re: Ignition switch replacement
I would try NAPA if you have one close, or online at http://www.rockauto.com Rockauto usually has ACdelco at reasonable prices. Leon
Thank you Leon.
Parts have been ordered.
No problem Alan. I have had good luck ordering parts from Rockauto.
LockDoc
