Old 11-29-2017, 10:52 AM   #1
FL71C10
292 Swap question
I am having problems with the 292 in my 68 C10, and it looks like I need a new motor, or to rebuild the old one.
I am buying a 292 from a member on here that came out of a 72 C20. It is also a 4 speed.
I hear about different starters on these motors. Will the flywheel from my old motor be the same as the newer 72 motor? The new motor doesn't have a starter, so I am hoping to just swap the starter from my old one. Will it be the same? Do I need to get a starter from a 72? I looked up the starters on Rock auto, and it is the same part # for a rebuilt AC Delco starter for both trucks.
I am getting the flywheel and bellhousing from the 72, so I should have all of the parts except the starter to do the swap.
Does anyone know what issues I might run into?
Thanks for any help you can offer.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 11-29-2017, 12:08 PM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: 292 Swap question
I think it's a direct swap. GM changed the size of the flywheel bolts at one time. I think, but don't quote me, that '67 was the last year for the small flywheel bolts.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 11-29-2017, 01:28 PM   #3
Husker
Husker's Avatar
Should not be a problem the starter mounts to bell housing.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
