Old 10-31-2003, 08:14 AM   #1
VTKidder
Instrument cluster lens; tach & vacuum
Used cluster lens with tach and vacuum readings. The lens is in good overall shape, and is only worn on the points where the lens rests on the 6 rubber pieces between the lens and bezel. There is one very small scratch across the '0' in the "80"mph reading. Other than that, it is in great shape, and the lens is still very clear. The scratches you see are in the top of the filing cabinet I took the picture on. If you'd like a much higher resolution picture, PM me with your email address and I'll send it off.
$25 shipped to the lower 48
VTKidder is offline   Reply With Quote
Old 10-31-2003, 09:09 AM   #2
MIDSTATE 67-72
LENS
PM SENT
MIDSTATE 67-72 is offline   Reply With Quote
Old 10-31-2003, 10:46 AM   #3
VTKidder
All yours MIDSTATE....PM sent. Thanks....
-adam
Old 10-31-2003, 10:49 AM   #4
VTKidder
Clean out your mailbox MIDSTATE!!! It's full!
email me at adkidder@us.ibm.com and I'll set everything up. Thanks.
-adam
