![]() Join Date: May 2001
Appliance Slotted mags, lug nuts needed, 8 lug
I have a set of 5 Appliance slotted mag wheels, 9.75x16.5. They use a shank lug nut I have never seen before. They are not the usual type of shank lug nuts. Any idea who might make these?
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
Re: Appliance Slotted mags, lug nuts needed, 8 lug
Check Summit Racing .Very similar to the Crager lug nuts on my Chevelle but different size and thats where I get mine .
I'll check that
Nothing at Summit........
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
The shank diameter on mine is .860. Haven't found anything with that size shank
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale Last edited by Joesjunk; 12-04-2017 at 10:28 PM. |
![]() Join Date: Oct 2009
might try these guys Joe http://www.akhwheels.com/pages/misc.php?cat=10
BlahBlahBlah
At the body shop.
Summit has them that size. You can search by that shank size. Use the narrow you results option.
Are they 1/2 or 9/16 thread?
SWB 4x4 Collector
![]() Join Date: Jun 2001
Joe, did you check Gorilla?
http://www.gorilla-auto.com/lug-nuts
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#11 | |
This place shows my exact lug nut, but not available. But they list a 2nd design. I'll call them tomorrow, thanks
They are 9/16", but none have that shank diameter.
#13 |
At the body shop.
I asked because our Frankenstein 68 is 1/2 in the back and 9/16 up front.
#14 |
![]() Join Date: Jan 2015
Hey Joe. I have a set of those lug nuts for an old set of Weld Wheels. I had to get a thicker washer so they did not bottom out. I believe they came from "JET"???
Jimmy Hoelzel |
#15 | |
#16 |
Excellent, glad to hear Joe.
#17 |
It's been about 10 years, but I had a set of turbines I bought cheap and new because they had both the newer chamfered seat lugs and one that was bored for shank type lug nuts. After a mishap with a free tire rotation at Sears and another after a flat repair where the techs didn't get the differences, I mic'd the shank nut, got a drill bit that exact size, and bored all the wheels to take the shank type lugs...problem solved!
Is that a possibility? I could go get the size off the bit or some new shank type 9/16" nuts I have. Hopefully those you have aren't bigger diameter. I'm thinking the outer bore is too big, though.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-06-2017 at 08:11 AM. |
#18 |
I have the same wheels in a 5 on 5. I've run into the same problem, these take a totally bastard lug nut. The problem is I can get a lug nut that will fit in the hole but there's no way you can get a socket on it because the nut sizes too big. Mine use a half inch stud and are going to need a 1/2 inch nut on the other side. A typical 13/16 nut for that half inch stud is going to be too big to fit a socket, even a thin chrome one,into the recess. Post a picture of the Lugnuts you get in the end, I'm curious.
Thanks, Steve weim55 Colorado |
