12-07-2017, 07:25 PM | #1 |
72 GMC Sierra Grande
Hi Guys I got a 72 GMC, Sierragrande I got a wood grain decal to redo my glove box door ? how is the badge held on the door can I take it off ? there is no studs on the inside of the door is it glued ? Thanks Saddletramp
12-07-2017, 07:46 PM | #2 |
Re: 72 GMC Sierra Grande
Ya , It's a sticky back
Stan 67 swb BLU MULE posted via flip-fone |
12-07-2017, 07:56 PM | #3 |
Thanks for the reply if I pry it off what kind of glue -adhesive can i use ??
12-07-2017, 08:06 PM | #4 |
It has barrel clips on the stud that pushes in and you can gently pry them off
12-07-2017, 08:10 PM | #5 |
xxx
12-07-2017, 08:19 PM | #6 |
Thanks for the reply if i pry it off can it go back on or will it trash the clips????
12-07-2017, 08:23 PM | #7 |
Moderator
Pry it carefully. It can be reinstalled with no problem.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-07-2017, 08:29 PM | #8 |
12-07-2017, 08:31 PM | #9 |
Sry if i gave wrong info , i thought you meant no studs on badge
12-07-2017, 08:41 PM | #10 |
Thanks Guys appreciate the help .Saddletramp
12-07-2017, 10:39 PM | #11 |
The studs only go through the outer layer of the door, so nothing is visible from the back side. The applique is glued to the door
12-07-2017, 11:04 PM | #12 |
Thanks Special K for the information appreciate you. Saddletramp
12-07-2017, 11:14 PM | #13 |
I forgot to ask what kind of glue would work on the glove box door for the SG badge??
12-07-2017, 11:28 PM | #14 |
Moderator
Here is a thread I posted years ago about applying the decal:
http://67-72chevytrucks.com/vboard/s...d.php?t=494583
